flat hood emblem not flush?
Old Oct 1, 2005 | 05:08 PM
enzo430S's Avatar
MB E430 Sport
OK, first of all, I did do a search and have read a dozen posts about this. I've read it and re-read it over the course of two days. But someone tell me once and for all if the OEM flat hood emblem is suppose to NOT be flush against the hood and stick out about 1mm? The hood curves right at that location of emblem, and it surprises me MB didn't make an emblem that also curved.
My other thoughts are may have the wrong emblem on my car (I have a W210), or I didn't push in the emblem far enough into the mounts.
Thanks in advance for any advice.
enzo
Old Oct 2, 2005 | 03:06 AM
MBZ12's Avatar
'07 R350. '05 C230. '93 454SS Truck. '71 Chevelle SS.
I took a look at mine and the fitment is not the greatest but good enough. As long as you don't have any significant gaps where water might seap in you should be ok. It's just one of those things I guess. I put a flat badge on my wife's c230 and it seems to fits better than on my E but it's the same deal. Go figure.
Old Oct 2, 2005 | 04:25 AM
Whitey's Avatar
98 W210 Advantgarde
There are two sizes of emblems, 1.75" and 2.25"....most common on the aftermarket is 2.25" but the dimple in our cars are for 1.75....so most of the time, they will sit outside the dimple and above the hood and not fully follow the curve of the hood but it is mimimal and almost flush if you tinker around with it.
The 1.75" (if available) should work better, although I've not installed or found one yet. My 1.75" AMG emblem has a curved base that fits into the contours of the dimple in the hood so it is flush.
Old Oct 2, 2005 | 11:14 AM
JimE430's Avatar
2000 E430, 2001 Harley Fatboy
My 2.25 fits flat, but you need to work at it. It is plastic and can mold somewhat.
Old Oct 3, 2005 | 12:48 PM
Ala-benz's Avatar
'00 E430, '83 Porsche 928S
I don't think that MB ever made a flat mount for the W210. All the flush mounts available are either aftermarket or modified from other models like the ML or SLK. Whitey is correct that only a 1.75" will fit correctly in the indentation. Many other owners have made the larger emblem fit to an acceptable curve.
Old Oct 3, 2005 | 03:12 PM
bob98e320's Avatar
1998 E320
Hey, even the w210's rear star is on a curved portion of the trunk!
Yeah, I have the flat aftermarket on the front and it is not 100% flush, but it is damn tight.
Old Oct 3, 2005 | 03:58 PM
enzo430S's Avatar
MB E430 Sport
I reverted back to the standing-star emblem because the flat emblem was not a perfect fit---I wish it was.
Old Oct 3, 2005 | 06:04 PM
4XFORE's Avatar
1998 E320 / 1992 LandCruiser / Project Car E30, 91, 318I
Jim, where did you get yours and how much?
Old Oct 5, 2005 | 12:07 AM
JimE430's Avatar
Believe it or not I got it at Smythe MBZ in San Jose.
Old Oct 5, 2005 | 11:19 AM
4XFORE's Avatar
thanks Jim. I will try Claridge in Newark.
Old Oct 5, 2005 | 01:20 PM
TruE320Ridah14's Avatar
2007 E550
I got mine also from there ($50 )
Does not sit perfectly flat but looks good though
Old Oct 5, 2005 | 09:54 PM
98MBE320's Avatar
Black '98 E320 4Matic
Just curious, why get a flat emblem? Why change it out from the standing emblem?
Old Oct 6, 2005 | 03:34 PM
2007 E550
I put the flat one on because my stand up one broke(my mom broke it on accident)
and the flat one looks nicer and give the hood more of a sleek look
Old Oct 9, 2005 | 01:48 AM
98MBE320's Avatar
True, but it's a classy hood ornament and makes a statement about the car you drive. Personally, I wouldn't want to hide it.
Old Oct 17, 2005 | 01:35 AM
enzo430S's Avatar
MB E430 Sport
I got the flat emblem to fit over the weekend. The emblem does not stick up anymore. Basically, with the emblem off the car, I tapped the emblem further into the moutning plate using a flat-head screwdriver and a hammer. I tapped lightly with a soft cloth under the face side of the emblem.
So now it's sitting flush with the hood.
