driver and passenger doors, noise!
Old Nov 2, 2005 | 11:48 PM
mbzmike's Avatar
1998 e420 ( 210 / 119 )
i am sitting here at a coffe shop in ontario, ca. i am sipping water, remembering the 370 dollars i just spent on a driver side mirror today. i am looking at a wallet with barley 4 bucks in it , ( mine ) . damn ! thats a lot of coin,for a mirror. but....! it works and looks good. !
anyways, here is the situation, upon exiting the car, ( e420, 97. w210.119) closing the door, my side or other side, the hindge kinda makes a creaking noise like a freaking rusted antique. reminds me of a ford ranchero i used to own, ( a 68 ) lord, that is antique to me !
i do not like the noise, i tried lubes, of all types, to no avail. is the hindge gone, or is there a oem oiler for these hindges. /? help ! thanks
Old Nov 4, 2005 | 12:35 AM
tomscia's Avatar
1998 E320 Sedan
My 98 E320 has the same problem with both doors. My understanding is that it is an engineering problem. I believe it can be corrected by replacing the straps betwee the door and the door jamb, but that requires removing the door panel I believe. Lube does not help.
Old Nov 4, 2005 | 09:04 AM
hubert's Avatar
14'G63 AMG ,1994 Mercedes E500, 2020 Range Rover HST
yes thats the straps they are like $25 each.
Old Nov 4, 2005 | 11:51 AM
Craig Ewing's Avatar
‘11 C300 ‘11 C350
Check the 10mm bolts at the door stops, mine were all loose and noisey.
Best wishes, Craig
Old Nov 5, 2005 | 12:45 PM
mbzmike's Avatar
noiz
straps, i will check into it asap. thanks, i assume door panel, interior, remains intact for replacement of the strap. if i'm incorrect, let me know, i'll go to ed soto page for 210 chassis info.
gracias
Attached Thumbnails driver and passenger doors, noise!-reno-diver-side-shot.jpg
