Rear Diff Hex Wrench Size?
Old Jan 7, 2006 | 04:04 PM
Elie's Avatar
2000 E320 4Matic
Hello, I just joined this forum.
I want to change the reat diff oil on my 2000 E320 4Matic, what is th size of the Hex wrench that goes in the plug?
it looks like it is between 14mm and 19mm. I have to buy this tool (allen wrench)
Please advise
Old Jan 8, 2006 | 11:21 PM
raymond g-'s Avatar
99 E320
da-yum, that's a biggie alright. let me know what you find. probably will be a
socket for impact wrench with hex type bit.
Old Jan 9, 2006 | 01:28 AM
tomscia's Avatar
1998 E320 Sedan
Try sticking modelling clay into the hex net. Then take it out and take the clay model to the tool store to compare sizes.
Old Jan 9, 2006 | 01:56 AM
cdiken's Avatar
2005 Carlsson CD32 E320 CDI Inline-6
14mm
14 mm internal hex on W211.
Not sure about w210.
Also, be sure to remove the FILL PLUG first, then the DRAIN PLUG. This applies to any vehicle. Diff drain plugs can be "stuck" and will strip out. At least if you have a stuck fill plug you can still drive the car if you discover it BEFORE draining the oil.
Let us know where you find it. Most stores only have up to 10mm, you can rule out Autozone, etc.
Old Jan 11, 2006 | 03:02 PM
Elie's Avatar
2000 E320 4Matic
Rear Diff Hex size----Thanks for all your replies
The size is 14mm just like the W211.
