projector question?
Old Jan 9, 2006 | 08:09 PM
Gomez153's Avatar
97 e320
projector question?
theres the long metal rod which has a lil hook like rod that connects to the projector hole ..the question is the back lid doesnt close unless you carve grooves in the plastic for the rod . my question is do you need these rods or can i take them off?
Old Jan 9, 2006 | 09:56 PM
raymond g-'s Avatar
99 E320
Probably would help for you to post pic or at least identify the manuf of your
projector housing.
Old Jan 10, 2006 | 12:36 AM
Mr. B's Avatar
'97 E320
What..??? did i understand you right..?? wait… what..???
sorry... no no uhmmm…
i’m thinking something else must be wrong… if you’re thinking the lid doesn’t close unless you carve some grooves in the plastic for the rod…
come-on now… maybe this is just me...
but you think it may have been designed that way..?? to require you to cut grooves… NO
next... your question... do you need these rods or can i take them off? WHAT
with-out knowing for sure… of what exactly you speak of… i’m just thinking now... but could they be there for a reason..?? YES
and as Raymond said… we need pictures or MFG. info… yep yep..!!
~ Mr. B ~
Old Jan 10, 2006 | 07:16 PM
Gomez153's Avatar
97 e320
this piece is what i was talking about. thanks guys
Old Jan 10, 2006 | 09:11 PM
ruffrob's Avatar
2010 Charcoal Grey E350 Coupe
Still no picture,Gomez. When posting a picture ,you need to put the URL of the image you want to post between these two icons 1.[IMG] 2[/IMG].Choose the word 'image' when creating your post,it's one of the choices above the box where you're writing the text of your post. It's how my car appears below. Good Luck
Old Jan 10, 2006 | 11:14 PM
Richard / E320's Avatar
2001 E320
Off thread; I was wondering what tires and wheels you have on your E...
Old Jan 11, 2006 | 07:13 AM
ruffrob's Avatar
Well,Richard,I have the 18" MB140 obtained from www.hlwcorp.com and tires
that are 235/40/18 ContiExtremeContacts from DiscountTireDirect.com. Hope this helps...
Old Jan 11, 2006 | 11:53 AM
zam2000's Avatar
S, GL, Escalade ESV, my shoes
Gomez,
That's just the lock that the manufacture put in so that when they ship, the internal won't move or crack. Simply remove it.
flip it backward, twist a little, and unhook it. You will have to do that before you can install bulb and put the back cover in anyway.
Old Jan 11, 2006 | 07:15 PM
ruffrob's Avatar
Not meaning to get off subject,but Zam,do you have or know where I can get the drivers side red/green blinker receiver plate for the keyless entry. Some jerk
recently was trying to get in my car,and thought all he had to do was fool with it. He must have thought I still had my Acura....
I've sent you a PM,as well
Old Jan 11, 2006 | 07:30 PM
zam2000's Avatar
Can you email me the pix of it, my email is hhbk@yahoo.com
If I'll check with my budy shop , if I found it, I'll send it to you.
Old Jan 12, 2006 | 03:55 PM
ruffrob's Avatar
Zam2000...This is the picture of the door...I've sent an email with the picture as well. Thanks for your consideration!!!
Old Jan 13, 2006 | 12:06 PM
Mr. B's Avatar
'97 E320
sorry but what’s that door handle lock part thing called anyway..??
or better yet the part number and/or a place to purchase it… I have a similar problem… just not near as bad as the one pictured…
thanks,
~ Mr. B ~
Old Jan 13, 2006 | 01:22 PM
ruffrob's Avatar
After some investigation,and a call to the dealership (Ray Catena Mercedes Benz)in Union NJ,it's called an infrared receiver (obviously),and they told me it would cost me $400....
Old Jan 13, 2006 | 01:29 PM
2001 E320
Thanks ruffrob;
I checked out their website; for the E-Class series it only shows the W211 chassis; how do I determine what wheel actually fits the W210 chassis... or did you go to the 14mm lug bolts?
Thanks!
Old Jan 13, 2006 | 09:28 PM
ruffrob's Avatar
Richard,you'll have to go for the longer bolts,the OEM's don't fit,but I believe they give you a set with the rims. Please know I found the website AFTER I bought them thru EBAY. They were $500 for a set of 4. Let me know if and when you get 'em. Good luck....
Old Jan 13, 2006 | 09:59 PM
lexrex's Avatar
'98 E320 4Matic, '85 380SL
Ruffrob, I noticed in the closeup of your door some pretty heavy swirl marks. A ~$10 tube of Meguiar's ScratchX and some elbow grease would take most of that out! Very nice car, BTW.
Old Jan 13, 2006 | 10:17 PM
ruffrob's Avatar
Lex,thanks for your observation. it's funny you should mention Meguiars',I just got the whole car care kit from a friend for $10 since he works at Target,so I'll be taking your advice,planning on giving the car some much needed care....
From the looks of your car, we have similar tastes.....
