why does the c43 have more hp?
Old Mar 14, 2006 | 11:14 PM
derek melton's Avatar
1999 E430 sport
why does the c43 have 302 hp. and tq. and the e430 only 276 hp. Is it the exhaust,ecu,air intake,cams?? both have the same motor?
Old Mar 14, 2006 | 11:28 PM
Alexbenz's Avatar
Sean's Sister--
hahahah, it's a complete different motor......amg is not the same as a 320 or 430.....complete different everything and also a bigger v8
Old Mar 14, 2006 | 11:41 PM
1999 E430 sport
they are both 4.3 and under the hood they say e430,s430,c43?
Old Mar 15, 2006 | 12:55 AM
Alexbenz's Avatar
Sean's Sister--
so??? enternaly they are way different......
Old Mar 15, 2006 | 01:26 AM
SDR's Avatar
SDR
'99 C43, '12 C63, '13 E350, '14 Sprinter
Same displacement certainly doesn't mean the same motor This is a large portion of the price difference between a sport and an AMG model vehicle. There's a lot more to the motor than bolt-on parts that any shadetree mechanic could perform. Look how hard it really is to squeeze another 30 HP out of that E430 motor!
Old Mar 15, 2006 | 08:57 AM
Ala-benz's Avatar
'00 E430, '83 Porsche 928S
Does anyone know the specific difference? They are the same base engine? I know that AMG hand builds the motors, but does anyone know what voodoo they do? I would think they certainly have a more efficient intake and exhaust.
Old Mar 16, 2006 | 07:25 AM
dafi129's Avatar
SL 55 , Infinity FX37, Aprilia Caponord Rally
AMG engine has different cams,different ECU parameters and different exhaust...That's the 30 odd horses....
Old Mar 16, 2006 | 01:33 PM
Whitey's Avatar
98 W210 Advantgarde
Agreed, a 30 odd HP increase is achievable with an ECU remap+performance camshafts+stronger valve springs+tubular headers+hi-flo filters and exhausts......at least that's what tuners like MKB, Kleemann & Carlsson are claiming.
Old Mar 16, 2006 | 02:07 PM
E43's Avatar
E43
2000 E430 Sport
I agree with dafi in that the difference is probably due to the cams, ECU, and maybe the exhaust. The only engine AMG has designed and built from scratch is the new 6.3L NA engine. All previous AMG engines were based on existing MB engines, although hand built with some performance parts.
Old Mar 17, 2006 | 11:46 AM
Mr.Gearhead's Avatar
2008 Aspen, 1970 Corvette, 2000 Corvette and 2009 Legacy Limited
Let us not forget... The C43 has 11:1 compression whereas the E430 has 10:1. Also, the C43 curb weight 3440lbs... E430 is 3985lbs. Every 100lbs is 1/10th of sec...
from an online source....
"Although the 4.3-liter V8 is basically the same as that used other Benzes, internal modifications by AMG result in 302horsepower and 302 lb-ft of torque. A near back-to-back comparisonwith a new CLK430, which has the stock, 275-horsepower version ofthe same engine, was most enlightening. If the C43 has only 27 morehorsepower, they're large horses. There is enormous powerimmediately, and it never fades."
Old Mar 17, 2006 | 05:32 PM
MB AMG's Avatar
2002 E55 AMG
But just like every other AMG engine (except for the M156) it is based on a base Mercedes engine.
Old Dec 24, 2006 | 09:50 AM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Nope they both share the same compression ratios. 10:1
Old Dec 24, 2006 | 01:45 PM
Air Marshall Eldritch's Avatar
John Deere
The 430 also has 300-lbs of torque. Take out the 500 pounds of dead weight and we have a pretty similar car.
Old Dec 25, 2006 | 01:05 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
You wish.
Old Dec 26, 2006 | 02:54 AM
Wadster's Avatar
'09 CLK550 & 2012 E350
The C43 is rated at least 3 miles per gallon less than an E430. It would appear that more horsepower comes with increased fuel flow.
Old Dec 26, 2006 | 11:12 PM
John Deere
Originally Posted by C43AMG
You wish.
Do you recall when I smoked you on the Turnpike in driving rain? Oh yes, you know.
Old Dec 27, 2006 | 08:02 AM
C43AMG's Avatar
Veteran: Army
Rick what you did was the equivalent of "automotive masturbation" - you were playing with yourself and the faster you went ......the more enjoyment........for yourself.
Old Dec 27, 2006 | 11:40 AM
John Deere
Well ok, but it felt good.
