w210 e55 AC,electric fans problem.
Old Mar 28, 2006 | 08:36 PM
mainroman's Avatar
02 E55
Hey guys,
I have a little problem with my AC in my 210, 02, e55, I noticed that two small electric fans upfront are not engaging when I use AC, so I my AC isn't cooling all that well.
Has anyone had this problem before? What can be wrong? I checked the plug and it seems that there is no power coming to the fans, but I'm not sure about that cos I tested it with the little bulb and I suspect that power can be irregular, like On - Off depending on the temp.
Could it be some sensor?? Or fan motors?
Any advice would be nice! Thanks.
Old Mar 28, 2006 | 10:20 PM
cragigotgame's Avatar
97 E420 90 300E
Yes It can be a couple things Ill let some of the other members chime in on this, but I believe that the accessory fans are a common problem on the W210. I know I had to replace mine last year.
Old Mar 29, 2006 | 12:08 AM
mainroman's Avatar
02 E55
Thanks cragigotgame!
I'm trying to figure out what's wrong with it. If I connect the fans to the battery directly they should spin right? Is it how you check if the fan is ok?
The other thing I was thinking about was relay, I know BMWs often have burnt relays. Or some sort of sensor.
Anyway guys, do chime in of someone has had similar problem or experience fixing it.
Thanks!
Old Mar 29, 2006 | 03:10 PM
mainroman's Avatar
02 E55
Anyone??
Old Mar 29, 2006 | 03:22 PM
JamE55's Avatar
Out Of Control!
mainroman,
Never heard of that problem before. I know mine kicks in when it gets hot at a certain tempreture. Not really sure about the AC part. Have your dealer check it out if you can.
Old Mar 29, 2006 | 03:28 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Several items to look at
Fuse ok?
Connections good?
Fans spin free?
A/C system may be low on charge...Low Pressure switch shuts fans off
Relay..
Fan Motors...Dont think that they would both be dead
Old Mar 29, 2006 | 06:44 PM
mainroman's Avatar
02 E55
AC works! It blows cold, but two small electric fans are not working.
Actually it's one fan, second is being driven by the belt.
I checked fuses, they are ok.
Any idea on where relay for the fan is?
I will try to check the fan motors today.
Don't want to go to the dealer though ;-(.
