Lowering my Car
The results depend on a number of variables - shocks, ride height, stiffness of springs, etc.
I lowered our E430 using #1 pads and E55 springs and shocks. This only lowered it about 1/2" and was due to the pads and not the springs. The ride is a little firmer, but still very 210-ish. On the C43 it has Vogtland springs and Koni adjustable shocks. It's firm, but doesn't "bounce" at all. The 190 has Eibach springs and old Sachs shocks with about 80K miles on them and it does bounce a tad. The bigger issue is that the springs bind because there is only about 2" of travel in the springs.
In my experience the H&R are decent springs and are a bit stiffer than the Eibachs. Personally I like the Vogtlands because they have more travel with the same lowering.
Note..You SHOULD roll the front fenders to avoid any rubbing as AMG does on its cars
I've looked into both H&R and Eibach springs; I'm told that are both similar in drop. A local shop I've spoken with recommends Eibach, but then I recently saw someone post complaining that his Eibach lowered vehicle sagged after a few years, so I'm not sure which spring is best.
I have been told that the OEM shocks do not have to be replaced to use either spring set up. I sure hope you'll post any information that you are able to obtain; maybe I'll quit talking and 'get-her done'... by the way, I have an appointment with another local shop this Thursday and will post their recommendations / suggestions.
possible that they use different gauge/winding, though both are clearly pro-
gressive wound. we just dont see the tech specs on poundage needed to
compare the two. so we're left with subjective evaluations from colleagues
with SOP observations. but i've been reading for a month now....and waiting
for my IRS return of $2k.
springs i considered were Eibach, H&R, and Vogtland
shocks considered were Bilsteins, Koni, and Eibach
looking like I'll be doing H&R and Bilstein HDs and #2 in rear and #1 in front
unless something earth shattering or otherwise compelling comes up
....yeah, i keep waiting on you to do the R&D first also...
https://mbworld.org/forums/wheels-tires-suspension-brakes-forum/81409-vogtland-brabus-out.html
What happens with my Eibachs is that on some bumps the springs compress fully which leaves no suspension. The Vogtlands have never done this since they have about another 1" of travel before fully compressing. Hope that clears it up a little.
suspension mod info for the past month or so and missed that one. okay
i get it now, fewer coils means more tauntly designed spring. i'll study
the specs and photos more now....thanks much! r-
p.s. so the Vogtland are single wound vs progressive of the H&R and Eibachs,
it appears, izzat it? also since the V springs have higher # rating does that
also mean that the car would sit tad higher than same length spring which
has tighter (lower #) coils.....all things being equal otherwise?
When I showed my Vogtland springs to a friend (before I got them installed), she said "they're purple! That's gay!" I told her you don't see them once they're on the car. haha
As for the V's, I find them to be a great balance of firm ride while still having a suspension. Some people go overly stiff and actually lose handling as a result. A car that bounces on every bump doesn't handle as well as one that can absorb some of them. There's a happy medium we have to strike given the road conditions we drive. I think ride comfort and height are worth expirementing with. I've sold a few sets of used springs for $25-$50 less than I paid after trying them for a few weeks. It was worth the investment to find the right mix to match the preferences of my wife and I. There's no reason to settle for less than what makes you happy when it comes to the car you drive regularly. Heck - we spend more than this on cable TV, Internet, beer and coffee each month
