E430: 2WD vs 4WD
Could some of you please post the pros and cons of the E430s with the all-wheel drive vs. the rear-wheel only?
I live in a temperate climate, and all I can gather is that the 4WD versions are better under winter driving conditions. In other words, why would I even want one. A persistant salesman is telling me that they are wonderful.
How about control, handling, and fuel economy?
Thanks in advance,
Musikmann
Weight
E430: 3,757 lb.
E4304Matic: 3,944 lb.
0-60 mph Acceleration
E430: 6.2 sec.
E430 4matic: 6.6 sec
Fuel Economy
E430: 18/24 mpg
E430 4Matic: 17/23 mpg
On the other hand, the 4Matic has been reliable. I have never seen problems posted regarding this system.
AWD is becoming increasingly popular, even if its advantages are not always clear cut in dry conditions. 4Matic should add to the resale value should you eventually sell the car.
Some have said that the 4Matic handles better and has better directional stability. I've never driven a RWD W210, so I can't compare. I can tell you that I can floor my 4Matic in a 90 degree corner and not break traction; it just whips around! Drive them both. Go with the one you like better.
Biggest disadvantage in mind of the 4Matic is that of the front end parts, such as shock absorbers and motor mounts, are specialized for the AWD versions. They're often more expensive to replace because there are fewer aftermarket alternatives. For example, the OEM front shocks on my car cost $200 each, almost double the cost of the OEM front shocks for the RWD.
You may be interested to know that the E430 4Matic comes standard with the E55 front brakes!
Thanks in advance,
Musikmann
Even if you don't drive in the snow I think you'll find the 4matic to be a better driving car in inclement weather. Mine is incredibly stable in the rain, and feels much more planted than a RWD car. It will have a higher resale, particularly in the Northeast/mid atlantic. I drove both before I bought this one, and I really noticed a difference.
Musikmann
I think the extra 200+ pounds all year round are not worth it, especially in a temperate zone. Let's face it, if you are driving this car hard enough to need 4wd in the turns, the e430 probably is not the right car anyway.
just my two cents.
There's also a penalty to pay in fuel consumption with the 4Matic you have to consider. Hope it helps.
Cheers.
Cheers.
Thanks, it does help.
