Auxillary Cooling Fan Runs Constantly
(100 degrees). Can I just replace the thermostat or could it be a sensor that needs replacing and how would I go about checking? New thermostats are relatively cheap - $20 or so and I would imagine relatively easy to install. Thanks to anyone that can help.
1) Check Radiator and Antifreez level, Radiator could be goign bad, or antifreez could be low. See if not fixed then,
2) Check engine oil level if low or not.
3) Replace thermostat. If not fixed then:
4) Possible senstors. If not
5) Take it to the shop
My oil and coolant levels are fine, the engine runs great and does not get hot at all. I'm quite sure that the problem is either the thermostat or a sensor telling the fan to kick on even though it is not supposed to yet.
1- Have u ever replaced thermostat?
2- Flushed radiator?
3- Replaced Water pump?
....etc jst to get a history of the car?
