Spring Pad Question...
Old Jun 6, 2006 | 06:55 PM
Richard / E320's Avatar
2001 E320
As I have previously posted, I just changed out my springs for a set of H&R springs but left the stock spring pads in place. My vehicle happened to have a #2 for both the front and rear. Can someone explain the pad size or size differences between the four that are availble for the front and the five for the rear? For example, would a #1 be shorter than the stock #1, and by how much? And does that translate exactly to the same amount of drop by using this pad?
I feel that the front of my vehicle could be slightly lower but not sure what the minimum gap should be so as not to incurr any fender damage.
<DIV ALIGN=CENTER>
You can see in this picture that the front wheel has more tire-to-fender gap than the rear.</DIV ALIGN=CENTER>
Thanks!
Old Jun 6, 2006 | 06:58 PM
JamE55's Avatar
Out Of Control!
In my experience just go with number # 1 pad all around. Should give you 1 finger or less clearance in the front and back. Looking at the pic # 1 pad should do the trick.
Old Jun 6, 2006 | 07:04 PM
E55Cent's Avatar
AMG 55, 335i, Mini Cooper S
#1 pads =5mm, #2=9mm, #3=13mm, #4=17mm and some say there are #5's
Old Jun 6, 2006 | 08:14 PM
2001 E320
Thanks to both JamE55 and E55Cent for the replies; I now know that a #1 pad would give me an additional 4mm drop. Looks like I need to save up for that furure 'minor' suspension modification.
Old Jul 26, 2007 | 08:18 AM
goualon69's Avatar
w210 e320 4M
is it possible to remove pads? and run without it?
on stock suspension
Old Jul 26, 2007 | 08:23 AM
illest's Avatar
w210 AMG or S213
I have heard that this can cause the suspension to creak. I am sure they are there for a reason
Old Jul 26, 2007 | 10:48 AM
uberwgn's Avatar
e300d
The pads act as isolators and they control the ride height of the vehicle based upon options installed at the factory. I cannot imagine running without them.
There are 5 thicknesses for the front, 4 for the rear.
Old Jul 26, 2007 | 11:12 AM
eXpLiCitW210's Avatar
I own a 1999 W210 Mercedes.
Question Question???
IM RUNNING ON 20" BRABUS MONOBLOCKS. WOULD NUMBER 1 PADS BE TOO LOW FOR A 20" WHEEL???
Old Jul 26, 2007 | 12:25 PM
raymond g-'s Avatar
99 E320
e-
the simple answer is 'no' it wouldn't be too low. all things being equal, the
gap would remain the same, provided your selection of tires is near same
as factory recommended (circumference). it's not the wheel size that
determines clearance, rather the tire selection. so if you have particular
tire size in mind you may want to mention that....as well as your preferred
ride heighth (wheel gap).
Old Jul 26, 2007 | 12:50 PM
Tire size
My car is sitting on 225/35/20 in the front and 245/35/20 in the rear. Thanks for your previous response.
-Leo
Old Jul 26, 2007 | 05:18 PM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Mercedes-Benz W210 Spring Pad Part Numbers:
#1 - 5mm = 210 321 0184
#2 - 9mm = 210 321 0284
#3 - 13mm = 210 321 0384
#4 - 17mm = 210 321 0484
#5 - 21mm = 210 321 0584
Old Aug 13, 2007 | 03:50 PM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
same part # for front & Rear??
Hey Jimmy, IS the pad part # the same for front and rear?? The dealership gave me two different part number, front is right and rear they gave me 210 325 0184.
thanks
Old Aug 13, 2007 | 05:02 PM
raymond g-'s Avatar
99 E320
Front
210 321 0184 5mm
210 321 0284 9mm
210 321 0384 13mm
210 321 0484 17mm
210 321 0585 21mm
Rear
210 325 01 84 5 mm
210 325 02 84 9 mm
210 325 03 84 13 mm
210 325 04 84 17 mm
Old Aug 15, 2007 | 10:25 AM
Originally Posted by raymond g-
Front
210 321 0184 5mm
210 321 0284 9mm
210 321 0384 13mm
210 321 0484 17mm
210 321 0585 21mm
Rear
210 325 01 84 5 mm
210 325 02 84 9 mm
210 325 03 84 13 mm
210 325 04 84 17 mm
Thanks ray, sorry I had only posted one set and not the other!
Old Aug 15, 2007 | 01:33 PM
raymond g-'s Avatar
99 E320
got yer six, brutha...
Old Aug 16, 2007 | 01:17 PM
goualon69's Avatar
w210 e320 4M
Can someone post a pics of these spring pads, and were they are instaled, i wonder how it's made!
Old Aug 16, 2007 | 03:00 PM
Here you go:
Old Aug 16, 2007 | 03:53 PM
goualon69's Avatar
w210 e320 4M
thanks, well apreciated
