Not again -- Defective ..
Old Jun 27, 2006 | 01:44 PM
E320Star's Avatar
2000 E320 Sedan
Exclamation Not again -- Defective ..
I keep getting this defective lamb error when I press my brakes. Accroding to the manual this is related to one of the tail stop, signal light beign bad. I replaced all and still the same issue. I noticed when I press the brakes, the tail stop light goes off instead of being on. Replacing the lamb did not fix it, to me it sounds like it is related to a brake switch or something, could it be? I replaced the brake switch 10 months ago !!
Old Jun 27, 2006 | 02:02 PM
patrick_y's Avatar
2006 E55 and 2002 E320
I hope this does not mean you have to replace the entire control computer for the lights.
Old Jun 27, 2006 | 02:24 PM
aviaator's Avatar
'98 E320 4Matic Wagon
Talking
Sounds like you'll have to take back to the sheep where you got it.
(sorry, couldn't resist)
AV8R
Old Jun 27, 2006 | 02:36 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Inspect BOTH Tail light bulb holders..They are Known to MELT and cause a Bulb check light..
Old Jun 27, 2006 | 04:19 PM
E320Star's Avatar
2000 E320 Sedan
No melt downs either on the bulb sockets. All look like new !!!!
Old Jun 27, 2006 | 10:23 PM
BOMBER's Avatar
1998 E320
Check your lic plate bulbs.
Old Jun 28, 2006 | 09:56 AM
E320Star's Avatar
2000 E320 Sedan
Talking
I found what the issue is. One of the tail stop lights seems to be causing issues even thu it looks like the orginal bulb and it is not burned !!! It all started when I replaced the bulbs 2 yrs ago which was a diff brand but the correct Sylvania P21/4W. I removed it and put back the original Philips brand on it and it seems to be ok. For how long it will be ok, who knows!!
Here is how I diagnosed the issue:
What I did to determine it is the bulb, is as follows:
1) I switched left w/the right socket including bulbs, then I pressed the brakes and issue moved from left to the right side.
2) Then I switched the bulbs only, the issue moved back to the left side. This tells me the socket is fine so is the wiring. It was 100% sure it is the fricking bulb..
Next time i am only buying bulbs from the dealership to gurantee no conficts..
Old Jun 28, 2006 | 04:41 PM
E320Star's Avatar
2000 E320 Sedan
So far so good. Issue has been resolved. see above.
Old Jun 28, 2006 | 04:57 PM
Were the (OLD) bulbs the SAME wattage? as the bulbs are marked..seen this before..The Bulbs MUST match as the Bulb check system measures resistance from the bulbs and if not the same it WILL turn the light on
Old Jun 29, 2006 | 02:52 PM
E320Star's Avatar
2000 E320 Sedan
nop, both have 12V 4 watts ... Still a mystery to me why one brand is better than the other !!
