Inside rear tire wear / E320 wagon
2000 E320 Wagon
Has anyone experienced unusually fast wear on the inside edges of the rear tires. I got only about 10,000 miles and the belts are showing. The front tires are fine. It is only the inside edge of both rear tires that is worn. There must be some alignment issues. Where do I look? Thanks!
2001 E320
What year is your vehicle and how many miles are on it? While an alignment is the most likely place to start, I would look at other components first if it had, say, 80k or 90k miles on it.
2001 E320
2000 with 85k. What components should I look at?
I'm not familar with the wagon set-up, but I believe it is different than a sedan. At 85k, it's been around the earth more than three times, so the suspension has wear, though since both rear tires wore the same way, it could be something as simple as an alignment.
2000 E320 Wagon
Does anyone know if there are adjustments for this type of alignment problem in the rear or if they would require replacement of components. It doesn't squat in the rear and the shocks seem fine.
E430
Things to check would be rear camber, rear control arms(bushings) and sagging springs (increases negative camber -> increases tire wear on the inside edges). Sorry, if the wagon has rear self-levelling, then you're probably gonna be looking at bigger $$ to fix.
I've got about 75K on my E430 and the rear end bushings are starting to get sloppy. Lots of side-to-side movement when hitting small bumps... Probably going to get some of those fancy adjustable control arms, seeing how I've already installed eibach springs.
Hope that helps,
-travis
Hope that helps,
-travis
Which is a better fix to rear camber adjustment?
I have exactly the same problem with the same vehicle. The right side is pretty bad. On a level surface, I arranged a bubble level to just touch the top and bottom of the wheel rim, and it was obvious that there was about 2.54 cm difference between the top and the bottom (i.e., neg. camber). The opposite side was neg camber less that 1 cm. I then gradually elevated the rear of the wagon wioth the wheels still on the ground (to determine if the rear end was squatting, thereby affecting camber), but saw no significant improvement in camber as the car came up. Also, there are no apparent worn bushings. For those who have dealt with this problem, which is a better method to make the camber adjustable?: installing eccentric lower control arm bushings, or the adjustable camber rod? Or perhaps something else, since I am only familiar with these two solutions? Thanks kindly.
209/W210 Estate /W211 modded by MBENZNL
I HAD the rear camber problem on my 2000 W210 Wagon.I Installed a set of adjustable camber bars..The rear camber is Now adjustable No More tire wear from negative camber..Also My Wagon IS lowered
The Camber bars AND the Kmac kit both will work..
I like the bars because the bars can be installed in 10 min
Where the Kmac kit requires the rear lower control arms be removed to PRESS out the old bushings..Aprox a 5 hour job...
BTW The Camber bars have been on my 2000 Wagon for Six years..WITHOUT any problems..
Here is one source I found, but I don't know it its the best.
http://speedybenz.com./
It was encourging to hear from Mark that this method works OK, because it seems very straight-forward compared to installing the eccentric bushings.
E320
House of Power in Huntington Beach
http://www.hopracing.com
Where do I find these Camber Bars and how much will they set me back.
K-mac
bushings in stock and rebuildable adjusts rear camber if lowered.
If your car is not lowered something is worn out.
or bent
or bent
2006 CLK 350 Fog City, CA, USA
Did you rotate the front tires to the rear then discover the problem?
That said, the rear suspension has a lot of multi-links with rubber bushing inserts that wear out, but maybe not at your mileage? That a screw driver and poke all the rubber bushing inserts of all the links and see if any of the rubber are deteriorated or weak.
Adjustable camber arms
I discovered the problem when I took to have tires rotated and balanced. The tires had approx. 20000 miles and the steel belt was showing on the inside of both rear tires. The car has 170000 miles on it but it really looks nice runs good and drives good. My thinking at present is to install the adjustable camber arms. The original camber arms have a slight curevature and the adjustable camber arms that I have looked at are straight. Will this be a problem?
profile1948
profile1948
You don't
need adjustable to correct a standard wear issue.
either bushings,springs or arms are bent.
Replace the worn items and it will be back to spec.
You use the custom links when lowering to allow for adjustment that takes camber way beyond stock non adjustable range.
www.autohausaz.com has all the stock suspension parts.
Thanks for the info ohlord. I understand what your are saying and certainly agree that would be the proper way to correct the problem. However, it sounds like a very expensive fix. I didn't want to spend a lot of money on the car and thought the adjustable camber arms would correct the camber and prevent excessive tire wear. The car is not lowered. My question is will this after market adjustable straight link fit where the original has a slight curveature?
thanks profile1948
thanks profile1948
2003 S210 3.8L Brabus wagon
thanks profile1948
thanks profile1948
Thanks for the info. My E320 wagon is self leveling and that may be the problem. I checked for leaks over the entire system and didn't find any. Is there some way to check the pump? The power steering is working fine.
thanks profile1948
thanks profile1948
