Sudden increase in my gas consumption (E320) Any suggestion?
I changed the plugs and wires but that didn't help. Fuel filter is also on the list. I'll be going back to mobil1 in another 500 miles... I may look into changing the MAF if nothing else works.
A few people have suggested that summer gas blend with ethanol will hurt gas mileage.
Any other ideas?
I needed one of the O2 sensors replaced because it failed. However, The CEL was on in my case. The service writer said that the car was running rich as a result, hence the decreased mpg.
I agree with the ethanol answers - I will not knowingly use ethanol-containing gasolines, but there are some areas where we don't have a choice. My main reason for avoiding it in all of my cars, is that I don't think it is good for the engines.
If switching to non-ethanol fuel does not help, I would try a tune-up next. I have a hard time swallowing any spark plugs in any automobile lasting 100,000 miles. Do you notice any difference in the way the engine performs?
Good luck,
M
21 MPG sounds low to me, let alone 18. I log every fill-up and calculate my mileage. I see about 24-25 MPG on average with mixed city/highway miles and get 28-29 on highway trips. I drive fast on the freeway (80-90 MPH) but generally accelerate slowly.
Gas and water don't normally mix in a station's tanks. The water settles to the bottom and the gas floats on top. Ethanol is a polar solvent, which means that it dissolves any water in the gasoline (bad).
Chris, in Miami
The original spark plugs have 74000 miles on them. My local "Pep Boys" would charge $240.00 to change them, but I would not entrust my E320 to them, except for an oil change... after taking a look at the engine, their mechanics told me it was an 8 cylinder! And I thought I knew nothing about engines! So, I would probably turn to my usual MB specialist. However, when he changes the oil he probably uses the cheapest brand available. Now I switched to Mobil 1, I really notice a difference (thanks to this Forum!). I don't want him to install the cheapest spark plugs either...
I came across a website http://www.lubedev.com/smartgas/tips.htm that recommends unusual solutions to improve mileage (for example: add 2 or 3 ounces of ACETONE into 10 gallons of gasoline and that will increase mileage "about 25-percent or more"). Either the author, Louis LaPointe, is a genius or a nutcase... But he has a huge website and appears to know a lot...He also has this advice about spark plugs (I quote):
"6. Use NGK V-Power spark plugs because they have a proper resistance level that will not short out the high voltage secondary during moist or very cold weather. Avoid platinum or palladium plugs. Other plugs (Champion or AC) have excessive resistance that wastes spark energy. Set the gap to .030 for best results for most cars. Too wide a gap causes a needless waste of amperage. The milliamps actually fire the mixture rather than the voltage. AMPS = HEAT. You cannot believe all the popular hype about VOLTAGE. But be certain your plug wires or cables are perfect. I now use the superb Kiker Wires for mileage. Replace your cables if they are over five years old. NGK also makes excellent plug wires. Bad cables will cause missing and poor MPG. Some plugs that come set at .060 can be reduced to .035. You may wish to contact PatKiker@yahoo.com for the best possible spark plug wires that will add MPG to your car or truck. We proved they work. See www.KikerPerformance.com."[/I]
I suspect my spark plugs are ripe for a change, but I would like to make sure I get the best for my E320 and also the correct adjustment. Would you have any further advice? Best, Chris (Miami)
!) Not only do I own a mercedes, but I work on them for a living. If there was something that could be done to increase fuel milage(additives, etc.) I would have probably attempted it. The Spark Plugs, oil, etc. that you can get from your local dealer are definately the best bet for your vehicle. The plugs that dealers sell are designed for your vehicle(I believe yours uses platinum plugs, and they are already gapped correctly unlike others from the local part store), and the plug suppressors(plug wires) are designed to have a specific resistance in them(your vehicle uses two different types of suppressor wires). Buying aftermarket(pepboys, autozone, Napa,etc.) wires, plugs, oil filters or other parts may be cost saving at first, but will probably have a negative impact at some point down the road. It may cost a litte more now, but you will thank yourself later. Hope this helps, If you have any other questions, feel free to let me know.
!) Not only do I own a mercedes, but I work on them for a living. If there was something that could be done to increase fuel milage(additives, etc.) I would have probably attempted it. The Spark Plugs, oil, etc. that you can get from your local dealer are definately the best bet for your vehicle. The plugs that dealers sell are designed for your vehicle(I believe yours uses platinum plugs, and they are already gapped correctly unlike others from the local part store), and the plug suppressors(plug wires) are designed to have a specific resistance in them(your vehicle uses two different types of suppressor wires). Buying aftermarket(pepboys, autozone, Napa,etc.) wires, plugs, oil filters or other parts may be cost saving at first, but will probably have a negative impact at some point down the road. It may cost a litte more now, but you will thank yourself later. Hope this helps, If you have any other questions, feel free to let me know.I think with the gas crisis that is going on that some states have dropped some envirornmental regulations and therefore changed some additives. But most of these changes should boost millage not deminish it.
Something else is going on with your car...
What is your coolant temperature? Is it above 80 degrees Celsius when the car is warmed up? If not, the thermostat needs replacing. They typically last 60k miles. The most often failure mode is partially stuck open and when that happens, the engine will take a long time or never fully reach operating temperature.
