19x8.5 ET25 & 19x9.5 ET28 on a W201
Old Oct 10, 2006 | 08:00 PM
Energie's Avatar
ok, I would like to know, what must i do to install these wheels on a W210 ... rubbing issues? ...
It's CLS AMG wheels. I just love them.
One question, what tire to use with 19s ... 18s is 235/40/18 & 255/35/18 ... for 19s ? can i use the same width and had /35 & 30 size to the tires?
Old Oct 10, 2006 | 11:33 PM
lexrex's Avatar
'98 E320 4Matic, '85 380SL
That's a negative. Won't fit.
You typically run 245/35/19 in the front, with the extra 10mm width to meet the appropriate load capacity.
Old Oct 11, 2006 | 08:45 AM
Energie's Avatar
so, for fitting these wheels, what must i do and tire size to use?
P.S. When i said W201 i mean W210
Old Oct 11, 2006 | 08:54 AM
lexrex's Avatar
You'll need to buy a different car. As I said in my previous post, those wheels don't fit the W210. The offset is WAY too low.
Old Oct 11, 2006 | 09:11 AM
Energie's Avatar
Ohhh ... what's the lowest Offset? And rolling the fenders? Sorry for so many questions but ...
Old Oct 11, 2006 | 03:05 PM
Energie's Avatar
well i just checked, and the SL63 wheels are 19x9.5 and 19x8.5 ET 35 ... so, is this a better solution?
Old Oct 12, 2006 | 11:45 PM
agentMurdoc's Avatar
What offsets are those rims? CLS rims should fit fine, since w210 typically require a lower offset like the CLS and R129. I fit some 18x10 AMGs on the rear of a W210 wagon and they have a 25mm offset. The fronts are 18x8.5 with a 25mm offset also, but I haven't fitted the complete set on, only one rear wheel (need to buy new tires and lugs).
If lowered will definitely rub, but very flush with the fenders and looks sicc Also keep in mind, my rear rims are half inch wider than those CLS rims (12.7mm)
Old Oct 13, 2006 | 07:48 AM
martz's Avatar
German
hope this helps
Wheels / Rims and Fitment
The W210 chassis originally came with one of the following OEM wheel setups:
* E300/E320: 16 x 7.5” ET41
* E420: 16 x 7.5” ET41
* E430: 16 x 7.5” ET41 (before 2000); 17 x 7.5” ET41 (after 2000)
* Sport Package: 17 x 7.5” ET37
* Special Edition: 17 x 8” ET35
* E55: 18 x 8” ET31 front, 18 x 9” ET35 rear
an et25 will bolt on obviously because it has the MB bolt pattern, but when mounted with tires it may stick out and cause rubbing
Old Oct 13, 2006 | 11:34 AM
Energie's Avatar
The sizes are these
2x 8,5Jx19 ET30 und 2x 9,5Jx19 ET33
Usually, what tire size do you use with 19s ( who has them of course ) ?
Old Oct 13, 2006 | 01:30 PM
martz's Avatar
German
using a 19 staggered set up then tires would be
245/35/19 front
275/30/19 rear
Old Oct 13, 2006 | 04:28 PM
By bolt on I mean that when mounted they were able to rotate freely, yielding a compatible offset that doesn't interfere with brake calipers and such. As mentioned before, will definitely rub if lowered. Still drove around a little bit with it on, too fresh 265's in the back would probably alleviate the rubbing issue.
18x10, 275/35/18 (excuse the poor picture quality, they were done on my phone)
Old Oct 13, 2006 | 10:31 PM
martz's Avatar
German
Agentmurdoc, your car has the profile the europeans go for, I like it.... sure has that appearance of a steamroller rolling down the road. But for me with a width like that I'd prefer it to be lowered, unfortunately though as you previously stated ..RUBBING .... so in essence energie's et 33 will be perfect
Old Oct 14, 2006 | 12:48 PM
lexrex's Avatar
Originally Posted by Energie
The sizes are these
Even though it's only a 5mm difference in offset, those new sizes should work much better than the ET25 front & ET28 rear you originally asked about.
Keep in mind that anytime you're near the limit of width & offset, the shape and actual dimensions of the specific tire you choose can impact rubbing. Not all "245" tires are the same physical width, and there's great variation in the shoulder design.
good luck
Old Oct 14, 2006 | 12:49 PM
lexrex's Avatar
Looks good!
Old Oct 17, 2006 | 01:12 PM
Energie's Avatar
Well, i wasn't able to get those wheels ... it was a ebay bidding session and my computer broke up 10 minutes before the end of the bidding... damn
Back to 18s i guess... damn wheels where sold for 560€ ($600 or so ) ... bahhhhh :|
Going back to Styling I AMG's 18x8.5 and 18x9.5 ET 44 & 46 with 10mm spacers from H&R ...
