Sunroof lubrication
Old Oct 26, 2006 | 10:37 AM
Air Marshall Eldritch's Avatar
John Deere
Sunroof lubrication
I've seen in the past that the MB lube was suggested on the pivot points and tracks. My question is would plain old CRC Industrial spray also do the job? This stuff is like WD40, but longer lasting. I use it on the sliding patio door tracks and such.
Old Oct 26, 2006 | 10:58 AM
uberwgn's Avatar
e300d
I'd stick with the approved product. It's unlike any lube I've seen.
Old Oct 26, 2006 | 09:54 PM
rhettnashmb's Avatar
2000 E430 sport
Hmmmm, I have used alot of lube myself !!!
ok, sorry......... just couldn't help it.
Old Oct 27, 2006 | 05:52 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Use only the OE MB Sunroof lube as Most other spray on lube will Gum up and cause problems ... its best to remove the guides and clean them BEFORE using the MB Sunroof lube
Old Oct 27, 2006 | 09:09 PM
uberwgn's Avatar
e300d
The good stuff:
