Gonna change out my sparkplugs, any recommendations??
Old Oct 24, 2006 | 08:18 AM
Little's Avatar
2001 E430 4matic
I read a few negative threads regarding the bosch platinums, which are currently in my car. What plugs are you guys running?? What are the factory plugs??
Old Oct 24, 2006 | 09:12 AM
lexrex's Avatar
'98 E320 4Matic, '85 380SL
I have the NGK Iridium IX. They work well and were cheaper than the OEM plug, which is the Bosch Platinum.
You probably read negative commments about the Bosch Platinum+4, which is an entirely different plug than the Bosch Platinum.
Old Oct 25, 2006 | 12:00 PM
Little's Avatar
2001 E430 4matic
I'm just gonna run a standard plug that is designed for this car and see how it performs. Maybe just a standard autolite or something. I'm not paying no $11 a plug when i can pay $3 a plug that does the same thing. I'll let everyone know the results.
Old Oct 25, 2006 | 12:04 PM
uberwgn's Avatar
e300d
Can you get a 100k mile interval out of a conventional plug?
Old Oct 25, 2006 | 12:25 PM
Huachipato's Avatar
'04 Cobra & '04 S430
I figured you may need at least a Platinum plug for 100K intervals.
Old Oct 25, 2006 | 06:01 PM
ccmbduong's Avatar
Check your manual and stay with your OEM plugs... everything else is not worth it
Old Oct 25, 2006 | 09:47 PM
ProV1's Avatar
MB, BMW
agree w/ comments above, stick with OEM only
Old Oct 26, 2006 | 02:37 AM
Eurosport's Avatar
monowiper
stick with oem
unless you do some really hardcore track time, changing to different plugs and wires is a waste of money
Old Oct 26, 2006 | 12:46 PM
Tommy_s4's Avatar
ML320, Looking for my S4
Try bosch 4 point plugs
Old Oct 28, 2006 | 12:39 AM
Blackbeard's Avatar
'01 E430 Sport
Your E430 came stock with Bosch Platinums. I just changed mine out a couple weeks back for the 1st time at 50k ('01 430) and plats were in there.
The OEM part # has been superseded with a new # .... they're only $7 a plug here:
http://catalog.eautopartscatalog.com...art=Spark+Plug
I've noticed a 2mpg increase and much more pep at lower RPM's since they were changed. It's a helluva job changing 16 plugs. Good Luck.
Make sure you have gloves, a 17 or 18mm open end wrench, dielectric grease and some anti-seize before you begin.
