Engine sound
Old Oct 28, 2006 | 11:46 AM
E320Star's Avatar
2000 E320 Sedan
Angry Engine sound
I have 2000 E320 with 59k miles, in the moring when i start it idles ok, after the idle it starts a noise like an engine knock noise. more like tappign sound. I already replace the spark plug, dealer replaced both Cat converters right and left, oil has been changed, new dealer air filter. What could it be causing this engine sound? But when I drive away and engine at normal operating temp, the sounds goes away completely.
Old Oct 28, 2006 | 02:18 PM
VIP ONE's Avatar
WALD out w210 and w203 daily grinder
is it like a hizzing sound? if yes, i think its normal coz the engine is still cold but when the engine start warming up, it goes away little by little.
Old Oct 28, 2006 | 03:18 PM
king_j's Avatar
tapping sound-lifters?
Old Oct 29, 2006 | 07:08 AM
the-1st-one's Avatar
E320
Could be the fan belt tensioner, can you see any vibration on it??
If yes it's it.
Old Oct 29, 2006 | 01:09 PM
E320Star's Avatar
2000 E320 Sedan
No idea what a hizing sound sounds like !! I will checxk the tensioner, but nor sure if i can tell for any vibrations !! That car does not smoke. I do not think it is the lifters !!
Old Oct 30, 2006 | 09:39 AM
E320Star's Avatar
2000 E320 Sedan
Today was warmer weather. the tickign sound on start up i ssoooo low. What else could it be?
Old Oct 31, 2006 | 04:42 AM
Howellja's Avatar
CLK, R350
Take it in!
Take the car in to the mechanic man! Dont wait for an idiot light!
Old Oct 31, 2006 | 04:54 AM
Howellja's Avatar
CLK, R350
could be a few things
Valve lash adjusted, sticky lifter, tensioner pulley. Not major issues, but could be if gone untreated.
Old Oct 31, 2006 | 09:00 AM
E320Star's Avatar
2000 E320 Sedan
thank u. i was trying to avoid paying $45 for nothing at the mechanic. Been there done that !! I will do that soon and rpt back on the issue when fixed.
Old Oct 31, 2006 | 01:32 PM
VIP ONE's Avatar
if its a hizzing or tick sound. it could be your water pump. its about to break down. but to make sure, just take your car to the mechanic and settle down.
Old Nov 6, 2006 | 12:01 PM
E320Star's Avatar
2000 E320 Sedan
Exclamation
Does the E320 have an engine sound sensor ?
Old Nov 21, 2006 | 02:28 PM
E320Star's Avatar
2000 E320 Sedan
The sound stays longer now....... but when i drive away it never comes back !!!!!!! what hick is it
Old Nov 21, 2006 | 05:34 PM
lkchris's Avatar
'10 CL550, '12 GL550
Perhaps ...
MODEL 210 with M112/M113 Engines
HYDRAULIC ELEMENTS "TICKING" NOISE DURING INITIAL OVERNIGHT AND/OR
COLD STARTS
In cases of hydraulic elements "ticking" noise during initial overnight and/or cold starts, replace the exhaust valve hydraulic elements with hydraulic elements part number 113 050 00 80 05. Note: Please DO NOT replace the rocker arm assembly, part no. 113 050 05 34. Replacing the rocker arm assembly to
repair hydraulic elements "ticking" noise is absolutely not necessary and extremely labor intensive. In case of warranty, please use Damage Code 05319 36
Old Nov 22, 2006 | 09:15 AM
E320Star's Avatar
2000 E320 Sedan
Originally Posted by lkchris
Perhaps ...
COLD STARTS
Is this a recall thingy too? My care is out of warrantee now. 60K mile sont he car and it is almost 7 yrs old. It is a 2000 E320
Old Nov 24, 2006 | 01:57 PM
Howellja's Avatar
CLK, R350
Take it in
Its been 4-5 weeks with this noise, Its getting a lil worse and occuring for longer during cold startup?
3 words-
take it in
Old Nov 26, 2006 | 11:50 AM
lkchris's Avatar
It's not a recall, but if you have a complaint under warranty, it will be fixed. Normally just the one ticking one.
This is the sort of information you can have if you buy the Mercedes service DVD.
Old Jan 4, 2007 | 10:47 PM
Airetime's Avatar
Noise at startup?
So what was the final answer to the noise at startup? Was it replacing the parts quoted by lkchris on the exhaust valves? I have the same clattering at cold statups which lasts about 10 seconds and then goes away. Will this damage anything or is it just irritating? What should the costs be? Anyone?
Old Jan 5, 2007 | 12:27 AM
gujupimpster89@'s Avatar
97 e420
probably sticky lifter
Old Jan 5, 2007 | 02:02 AM
BeNzTeK's Avatar
Make sure it isnt your purge VALVE I have worked on plenty of benz's with the owners stating what you just did ! The purge valve will tick every 8th of a second.
Chances of it bieng an exhaust valve is very slim!
If it is a lifter if left alone it will chatter up your cam therefore it will be very expensive!!
Bring it to a shop see what they say..
Old Jan 5, 2007 | 08:52 PM
E320Star's Avatar
2000 E320 Sedan
when i took my car for an oil change last time, i mentioned it to the dealer. he asked me to leave it overnight to check out the engine sound. I have not done so yet. When I do I will rpt back to all. However, the dealer did say it is possible a dirty lifter and it is nothing serious to worry about. But u know the human nature !!! I must take it in when i have xtra $$$ !!
Old Jan 21, 2007 | 01:13 AM
Airetime's Avatar
Noise at startup FOUND
Not stickey lifters! This one is a bit. I opened the hood and found that the fan was hitting the radiator fins towards the bottom of the radiator. Thoughts of $$$$ went through my head thinking about the costs ofa new radiator but it looks worse than what it actually is. Since it has been cold the fan would start but then stop after about 20 seconds. I checked underneath and found that the bracket that holds the radiator was pushed up and back and the radiator rubber knob that normally fits snug into a hole in the bracket was popped out allowing the radiator to move about. My wife had popped over a concrete parking stop a few months ago and at first it didn't look like there was any damage and I forgot about it.
A rubber mallet and a piece of 2"x2"x36" wood allowed me to pop the bracket down and reposition it (hydraulic jack) so the rubber knob popped back into place securing the radiator. Started it up and no more clattering! It could have been very expensive.
