Bad result after repaint my car.. :(
Old Nov 23, 2006 | 08:43 AM
MoNd3sTo7's Avatar
W210 E200K
I got my car come out from panel and paint shop 2 week ago.. But the result come out very bad.. now my car look two different color now.. anyone know why? the paint code should be correct.. cause he told me the paint code is 744.. if that guy had the correct code number.. The new paint should be match with my old paint right?
Old Nov 23, 2006 | 09:20 AM
E320Star's Avatar
2000 E320 Sedan
obviously not !!! Did u paint the entire car? or where needed only !! There is no way u can match the color 100%
Old Nov 23, 2006 | 10:33 AM
slk55lvr's Avatar
Brand new paint can never match the same color code of paint that has been sitting in the sun/rain/snow for 10 years. A real good paint shop mixes to adjust the shade, and obviously this was not a real good paint shop. You are better off painting the entire car now.
Old Nov 24, 2006 | 01:43 AM
suicidal4life's Avatar
2001 E430
In addition to the painter custom tinting the paint to match they will often paint any adjacent panels (IE if you are replacing a fender he would paint the hood and door) blending the new paint across the adjacent panels so it is a gentle fade and is less detectable. It sounds like you went to a shop that does not do very high quality work or perhaps you were not totally clear on what you expected from them.
Old Nov 24, 2006 | 07:20 AM
ccmbduong's Avatar
I was in a color matching technology for my past company for years and it's almost impossible to color match paint (new vs.old) , and also because of the sheen due to aging effect
Good Luck
Old Nov 24, 2006 | 11:39 AM
W211 Ryda's Avatar
2004 E320
Good Luck
my car is garaged about 98% of the time...detailed monthly so the paint is in pristine condition. i got a minor dent in my hood so that needs to be repaired and painted. i will be taking it to a high quality body shop, but I'm wondering how close could they get to matching the original paint? I heard silver is hard to match and there could be a slight variation at certain angles. any tips would be appreciated!
Old Nov 24, 2006 | 12:23 PM
hubert's Avatar
14'G63 AMG ,1994 Mercedes E500, 2020 Range Rover HST
Silver is very hard color to match thats why a good quality body shop will blend your two fenders so it looks even.
Old Nov 24, 2006 | 08:20 PM
2001 E430
If the dent is small enough and not too near the fenders they can probably blend the paint across the hood. If its large, near the fender, or the whole hood is replaced they will probably need to blend the paint across the fenders.
Old Nov 24, 2006 | 11:05 PM
MoNd3sTo7's Avatar
W210 E200K
I just needed my new paint on the fender only.. Not the whole entire car.. I went back to complain yesterday.. they told me will adjust and repaint my car again.. SO here (PIC) is the result after got the new paint.. Anyone can see the different colour between the fender and door?
Attached Thumbnails Bad result after repaint my car.. :(-car1.jpg
Old Nov 25, 2006 | 01:35 AM
W211 Ryda's Avatar
2004 E320
wow, sorry to say this, but that paint match looks horrible. fender looks darker.
Old Nov 25, 2006 | 06:58 AM
MoNd3sTo7's Avatar
W210 E200K
Yes, you are right.. the fender looks darker.. hopefully this time they can do better job than before..
Old Nov 25, 2006 | 07:34 AM
benzmodz's Avatar
W203 slightly modified
Paint analysis comes under several factors.
- Mercedes batch number based on age of car
- UV exposure
- Paint code
My car has 1 paint code and 5 variation codes based on the age.
Paint matching is an artform and only people who have been active in the area for a long time actually get great results.
Old Nov 25, 2006 | 09:12 AM
SUNILP's Avatar
2015 E250D
- UV exposure
- Paint code
I second that.
Old Nov 25, 2006 | 12:19 PM
John H's Avatar
14 E550, 07 E550, 69 Mach I, 65 Hipo, 66 Fairlane GTA Conv, 66 Fairlane GT
Color matching is an art!
With metallic colors you also need to match the same spray techniques. Even paint shot from the same can have different shades when dry. Fast drying or a thin coat of paint will have a lot of sparkle and appear light. Slow drying or thick paint, where the flakes sinks to the bottom layer and get covered more by the pigment, will look darker.
A competent shop with a good painter is expensive and worth it!
Old Nov 25, 2006 | 01:16 PM
Richard / E320's Avatar
2001 E320
That's why every vehicle I buy is 'white'; metallic colors are beautiful, until it's time for a repair... even small rock chips aren't as noticeable than a metallic.
Old Dec 3, 2006 | 09:07 AM
[iNTx]'s Avatar
W210, W220, W203
Isnt that in Singapore?
I thought C&C did make a good job on my car.
Old Dec 3, 2006 | 10:47 AM
MoNd3sTo7's Avatar
W210 E200K
No.. Im from Brunei..
