E320 will not automatically shift when cold
An interesting point: I've discovered when driving before it is light out that the selector does not light up "D" when the automatic shifting is not working. That certainly suggests to me that the problem is in the electronics that sense the selector position, yet I don't understand why it would only be a problem while the engine/tranny are relatively cold and temp is below 40 degrees. My sister-in-law has an almost identical W210, and she did the spilling the Diet Coke in the console trick and the tranny would not shift at all. I'd suspect my fiancee may have spilled something while she was driving my car, but any problem from liquids getting into the circuitry should be a problem at all temps, not just cold weather????
Ordered the DVD shop manual a few minutes ago, and hoping it can shed some light on this. Meanwhile, has anyone ever experienced this?
Have a shop look at the Transmission Control Module. Also see if the car throws back any codes when checking with Star Diagnostics, which can only be done by a Mercedes shop.
you mentioned codes that only the MB dealer can read. Is the MB not compliant with the OBD-II requirement?
I don't think the average consumer can even buy these Star units.
Good luck and welcome to the forum,
Musikmann
please let me know if you have any luck with a solution and i will do the same if i have any luck.
Turned out a simple reflash solved the issue
Was worried it was a shift solenoid or worse a trans.
$100 and I was on my way been a yr now not one glitch at all.
I opened the heated vent in my glove box, and the problem went away. I think that moving warm air past the shifter module warms it. However , if this works, it means the module is failing and should be replaced.
