For all the non belivers
anyways good luck with ur project
The differences between these bulbs is the colour temperature rated in K (Kelvin). This rating system is not rated by the brighter the bulb the higher the Kelvin rating.
Think of the colour rating scale as a rainbow instead. A standard incandescent bulb in the traditional shape that is common to the old style reading and coffee table lamps is rated at about 2400K to 2600K. A standard halogen headlamp bulb is rated at about 3000K to 3200K. Early generation HID systems where rated at about 4300K to 4500K and current generation HID systems are rated at about 4000K to 4250K. Just as a reference point, sun light at high noon on a clear day is rated at about 5000K to 5500K depending on the season, level of pollution in the air and your location on the planet. A cloudy day at high noon can be rated at about 6000K to 7200K.
Now that you have all those figures, let's think of the rainbow concept that we mentioned earlier beginning with the red side which is the incandescent bulb rated at 2400K to 2600K. As you move through the spectrum you will go through orange, yellow, white and then start to go into the blue and finally ultra violet. As the human eye sees light we all note that blue is actually the hardest to see with. This of course is due to the fact that blue light has the shortest wave length and is not recommended for good vision. Hence the reason that most current generation of HID systems have gone to a lower Kelvin rating. Rainy weather is the worst to be using bluish light in because the wet surfaces actually absorb the blue light and give you little return of information on what is actually there, sight wise.
The other factor into why something is brighter is a simple one, output wattage or intensity. Just because the sun is the brightest thing around doesn't mean it has the highest Kelvin rating. Cloudy days are dimmer than sunny days yet the cloudy days have a higher Kelvin rating. Confused enough? We hope after you read this a few times you will understand, most usually understand it the second time around.
So to summarize the answer to the question, a higher Kelvin rating has nothing to do with brightness as far as headlamp bulbs are concerned. Wattage and design of the headlamp bulbs and housings have everything to do with brightness and output. Also keep in mind that all higher wattage versions of any stock wattage bulbs tend to last a shorter time. "
tommy ur car is coming along nice, keep it up...
Really, all I think you need is Tint, lower 1.2 inch or so, rims, those tails that you ordered, the spoiler that you have ready, and a flat hood emblem from dfw.
tnx for the info on the powerchip. geez those are some wild claims...28hp
gain??!! i hope you get a chance to dyno your ride before and after so that
you can determine the original baseline from which to compare.
how about you and I take a step back and start over, aw-ite? this forum
definitely is not lame and is a great source of info from various 210 owners.
the mods we make can be extremely helpful to others with same model.
it's understandable ....even presumed...that there is a bit of uhm, embellishment
which goes on here. but we should all try to be factual about our claims so that
the information is helpful and doesn't lead others into purchasing items which
may end up not helping at all.
hey, who knows, maybe we'll hook up sometime if i'm in your part of town.
peace, muh brutha
peace, muh brutha
hey sounds good, as for the tints and the rims and the drop. NYC is a ***** the roads are more busted then a hooker in a third world country. If i droped it and lord knows how i drive, i'd have a bent radiator, oil pan riped off, 4 bent rims, and somehow my trany would be in the street somewhere. But i still wana lower. but i mean one thing leads to another.
