Can I get wheels with these specs to fit on my W210?
FRONT: 18" x 8.5" ET44
REAR: 18" x 9.5" ET46
Car:
Basic E320 W210 (no 4Matic or auto-level suspension)
I understand about offsets and I know these offsets and widths are quite a bit different from what is recommended for W210.
With that in mind, I'd like to know:
A) Is it possible to get these wheels to work using H&R spacers?
B) If so, what width spacer?
C) What are the pros/cons of such? (wheels poking out of fenders, etc...)
I'm not worried about bolts or tire sizes yet (one step at a time). Luke, I will definitely order from Tire Rack (I always do). I just want to verify that the wheels will fit before I buy them. If it's not possible to fit them, discussing tires and bolts now would be pointless.
Thanks in advance.
C
Cons
You're using spacers
You're increasing rolling resistance and decreasing fuel economy
You're decreasing wet/snow traction
You will need low-profile tires, which are susceptable to
-increased wheel damage
-rough ride
-flat spotting from sitting
You're just paying for ego--and paying more--because you will NEVER experience increased performance.
Cons
-rough ride
Do you know if they will fit?
- your offsets for your car avg 35mm
- you're going 10mm over
- the rims and tires will stick in even more, and may rub
- spacers are needed. exactly how thick depends on actual tire, but figure 10mm
- will it rub fender? possibly, but again, this depends on rubber (different designs
do vary by millimeters)
- do you plan to lower? any spring mods? any shock mods? blah blah....
- weigh the aesthetics
- trust Luke's Force. he's in a position to guarantee performance and has much
experience.
experience.
Facts like:
- "Yes they will fit using [x]mm spacers"
- "So-and-so did this on his W210 and it worked fine."
or
- "No they won't fit because there is not enough width in the wheel well to handle them."
- - "So-and-so tried this on his W210 and it didn't work."
Tires aren't an issue. I will buy the proper tires when the time comes.
These won't be my "winter" wheels.
This car isn't a daily driver.
(Audi B5 A6 4.2)
Will the wheels in my original post fit on my W210 or not? If so, how?
Model E55 AMG
Layout Front-engined, Rwd
Size (L / W / H / WB) mm
4795 / 1799 / 1436 / 2833
Engine V8, sohc, 3v/cyl, VVT, twin-spark, variable intake.
Capacity 5439 c.c.
Power 354 hp
Torque 391 lbft
Transmission 5A
Suspensions (F/R)
double wishbones / multi-link
Tyres R: 265/35 ZR18
Weight 1635 kg
Top speed 155 mph (limited)
0-60 mph 5.3 sec*
0-100 mph 13.0 sec*
