HELP!!! Service B
Old Jan 31, 2007 | 02:19 PM
TASHO's Avatar
HELP!!! Service B
Light just came on, needs to be serviced in 500 miles...What does it consist of? I drive an '02 E430
Old Jan 31, 2007 | 06:22 PM
OldNate's Avatar
1998 E320
A rip off. It's basically an oil change, and then they "check" a bunch of other things. If something is wrong with these other things, then you will have to pay extra to get them fixed.
Old Jan 31, 2007 | 06:28 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
Basically a tune up and an oil change. They also lubricate the door hinges, change the interior blower filter, measure the thickness left of the brakes, the % of tires remaining, top off all fluids, and check things like belts, hoses, condition of fluids, gaskets, etc. If you want to save a few hundred bucks, change the plugs, wires and airfilter yourself. Good luck. Hopefully they dont find much.
Old Jan 31, 2007 | 06:55 PM
Air Marshall Eldritch's Avatar
John Deere
The "b' in b-service stands for 'butt', or where they insert their tools. As already noted, it isn't much more than a fancy oil change. If under original warranty, may as well bite the bullet and smile. If not, go to an Indy and get an oil change.
Old Jan 31, 2007 | 10:55 PM
TASHO's Avatar
thank you guys, appreciate the help....anyone know how to change the filter and how to reset the service b indicator light?
Old Feb 1, 2007 | 01:38 AM
Lancelot's Avatar
'01 W210 E320 CDI
I think you should ask around for a good MB specialist in your area. The shop I take my car to is run by two brothers whom are dealing with older MB all the time. Their showroom is filled with previous models and they are experts that don't want to rip you off. ie if they find something on the exhaust they call me up if I want it welded or replaced, and on my W124 they even switched rear brakepads from left to right so they would wear out evenly! Get this: they still have to remove the wheels and pads and clean everything; the stealer would simply put in new pads while not yet necessary...
Old Feb 2, 2007 | 03:11 AM
Richard / E320's Avatar
2001 E320
http://www.geocities.com/mymercedesb...e_a_and_b.html
