Metal knock underneath car
Old Feb 8, 2007 | 12:26 AM
dontbirdme's Avatar
Hi All,
I need help. My 01 E320 4Matic has this metal knock. I suspect it is metal because when I occassionally turn or go over a pothole/bump, the noise echos and lasts for half a second. I moved the exhaust pipe around but couldn't duplicate the problem.
Any takes or similar experience?
Old Feb 8, 2007 | 07:48 AM
SaMaS's Avatar
02 996 Turbo, 05 CLK55 AMG
Hi maybe one of resonatrors ?
Old Feb 8, 2007 | 11:29 AM
RickyE430's Avatar
2001 E430 Sport
I bet it's a cat. Dealer replaced mine under the emmisions warranty
Old Feb 8, 2007 | 12:06 PM
dontbirdme's Avatar
Thanks for the response.
I'm thinking, if it is the resonator or cat, shouldn't there be a sound even at idle?
The metal noise only occurs when I turn or hit a pothole, not when idling or going in a stright line without hitting potholes...
Old Feb 8, 2007 | 01:49 PM
EdzBenz's Avatar
W210 W140
You will hear a sound at idle as the cat deteriorates over time.
Old Feb 20, 2007 | 12:16 PM
dontbirdme's Avatar
The noise seem to be on the passenger side, and it seems to be coming from somewhere near the trunk. I had my cat replaced by the dealer 2 years ago already so it is not the rattling noise that i've heard of before. It sounds like a spring or a metal impact... not quite sure. I rock the car up and down but I can't replicate the noise...only on occassional bumps and turns. Any other ideas? Could it be a worn rubber spring stop or something?
Old Feb 20, 2007 | 07:33 PM
EClass_VIP's Avatar
It might be possible that your spring pad is worn out.
