Stainless steel brake lines? NEED HELP
Drivers side stock line has ruptured and I am considering replacing all lines with braided steel lines. It is a '96 E320 w/ABS and double pin rear brakes. Does anyone have experience or suggestions with any brands or manufacturers??? Please post links or suggestions...
Many Thanks!!!
p.s. - Goodridge is the manufacturer !
Most brake fluids are DOT 3 - good enough for the street and normal driving (if there is such a thing). If, however, you run your car at high speed events like your Porsche, BMW, Ferrari, etc., club track days, DOT 3 just won't cut it.
DOT 4 grade brake fluid has a higher boiling point so it helps prevent bubbles forming in the caliper at high disc brake temperatures. When you're really hammering the brakes (braking from triple digit speeds lap after lap) the heat in the disc and caliper can get so high that it can cause the fluid to boil and at best, give a spongy brake pedal feel. At worst, your brakes can go away completely (that's change your shorts time!). ATE makes a good quality product. They make brake components (e.g., calipers) so they really know what works.
I (and many of my track-junkie friends) have been using this fluid with good luck for years in our German cars. Also important, it has never damaged the seals (I am told that it can happen with some products). Change your brake fluid at least once a year and bleed it before every track event for maximum safety.
wow i didn't know that....
attack certain rubber parts. regardless, stick with the recommedation
outlined in the owner manual. the info recommended within is usually
predicated on what has proven effective....and is comfortably within
warranty parameters.
I knew I was asking the right bunch!!! I'll Post back with details on the repair/upgrade when the work is completed.
Thanks again to All,
Wayne
On the track, SS lines should be a 1-2 year replacement item anyway for safety.
Ford brake fluid is great, cheap and plentiful at your Ford dealer. Don't use ATE blue, unless you want your brake system, reservoir and break bleeding equipment permanently stained. Off the shelf Valvoline Syn-tech works fine also.
David
