How to check Front Seat Ocupnt Sensor?
Old Apr 16, 2007 | 11:20 AM
eppy's Avatar
2002 E430 4MATIC
How to check Front Seat Occupant Sensor?
Is there a way to check the front seat occupant sensor? I found a break in the wire and fixed it. I am still getting the light. I was wondering if I could disconnect the yellow connector under the seat and meter the wires to see if the sensor is bad.
Anyone have an idea?
Old Apr 18, 2007 | 04:43 PM
eppy's Avatar
2002 E430 4MATIC
How do I reset the light? Maybe I fixed it but I need to clear the code from the computer? Will pulling the power cable work?
Any help please?
Old Apr 18, 2007 | 04:45 PM
mv420xx's Avatar
try disconnecting the battery, step on brake several times then reconnect.
Old Apr 23, 2007 | 11:15 AM
eppy's Avatar
2002 E430 4MATIC
Is there any way to check the seat recognition sensor? I found a wire cut and repaired it. But I still have the SRS light and the air bag light on the console all the time.
Found out the sensor is $250. Is there anyway to check the sensor say with a voltmeter before I go and buy one?
Also, I ordered a OBDII reader. Will that tell me the code for the sensor and can I reset that light with the reader?
Help please!
Old Apr 23, 2007 | 11:17 AM
eppy's Avatar
2002 E430 4MATIC
By the way, I left the battery disconnected all night and that did not reset the light.
Old Apr 23, 2007 | 01:04 PM
Huachipato's Avatar
'04 Cobra & '04 S430
My light comes on, but at times goes off depending on how my wife is sitting. Leads me to believe that you did not correct the issue. Once the issue is corrected, I would think, based on my experience with the light going off occassionally while in motion with a passenger seated, that it will go off on it's own.
Old Apr 24, 2007 | 09:55 AM
eppy's Avatar
2002 E430 4MATIC
For $250 I'll take another look at it.
