retrofit power rear sunshade
Yes it can be retrofitted...
NO The car is NOT Prewired for the option..One Must add the wire harness and replace the wood panel for the shade switch
Contact Steve @ MBENZNL.com re the parts
If You want to TRY to do this ..One WILL Need a Copy of WIS from Mercedes benz
I have heard a lot of good things about Steve with http://www.mbenznl.com and have always received answers to my questions. Either he, or his female assistant (I heard from Wanda in his absence) will get back to you.
The procedures includes two main steps:
retrofit wiring harness
retrofit sunshade
The former involves removal/replacement of lots of the interior as the wiring harness runs from underhood to the rear. You'll also be removing the center console to install the switch, which requires a different piece of wood.
The sunshade installation appears fairly simple, as it's a complete rear shelf replacement.
