Battery disconnect
Old May 28, 2007 | 10:35 PM
ohlord's Avatar
Cool Battery disconnect
Another tip that's not in the owners manual.
In the passenger side foot well is an access whole covered by a plastic door.Open it up and you can disconnect the negative terminal of your battery,without having to remove the back seat.E320 at least....
ohlord
p.s.
Have your radio code handy
Old May 28, 2007 | 11:18 PM
raymond g-'s Avatar
99 E320
that one was in my manual (99 210). here is another tip (in manual also) is the
existance of POS terminal in the engine bay. saves having to pop the rear seat
when attempting to jump start the car. i've also used this to power a small
trouble light' which I store in the engine compartment for emergency use after
dark.
i went for 2+ years before i realized there was an oil check mode via dash.
shortly afterwards I discovered that instead of pressing buttons, I can also
do this by pressing the brake pedel about 7x, to trigger oil check.
Old May 9, 2008 | 12:42 PM
youseffex's Avatar
E280 1998
ohlord
p.s.
I want to disconnect my battery
I opened the plastic door but I found 12 fuses, which one is for the battery?
Old May 9, 2008 | 01:20 PM
ohlord's Avatar
Yours
must be different,the door is on the vertical part of the footwell next to the trnasmission hump in the rear seat area.If your model has fuses in there you need to lift the seat to ger at the battery.Have your radio code handy and be prepared to resync all the things that need to be re synced after battery disconnect.
ohlord
http://w210.pietrzyk.net/disassembly_electrical.htm
Old Feb 4, 2009 | 05:38 PM
youseffex's Avatar
E280 1998
ohlord and other dear members, I found the door for the battery circuit, but I can't get the nut locking the wires to budge ,, i tried everything
Old Feb 5, 2009 | 11:23 PM
TMAllison's Avatar
09' E320
Remove the rear seat and get more room to work.
