Check Engine Light Codes P0432/P0422
Old Jun 25, 2007 | 08:29 AM
delray's Avatar
On my 2001 E320 AWD wagon [94K] I'm getting these 2 codes only:
P0422 - Main Catalyst Efficiency Below Threshold (Bank 1)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
I've cleared the codes often and within 15 restarts they reappear again with the CEL staying on till I clear it again.
Work recently done:
new battery
new Bosch spark plugs +2
New air filter
Cleaning of the MAF with CNC cleaner
High test gas only
Wagon runs strong with no hesitation at all but the CEL reappears with the same messages:
P0422
P0432
Help with any suggestions at this time!
Old Jun 25, 2007 | 02:20 PM
ohlord's Avatar
Smile Cel
Bad cat,You are over 80 thou so the dealer won't replace.Someone will chime in with an aftermarket part that will do the job and not cost an arm and a leg,like the dealer cat.
ohlord
Old Jun 25, 2007 | 02:30 PM
ohlord's Avatar
Smile bad cats
If you have a good shop near by they should have the ability to splice in replacement cats,for less than $200
Anyone with a link to those mercedes universal cats that run about 60 bucks apiece?
Are they rattling?
ohlord
Old Jun 26, 2007 | 05:37 AM
jlmills's Avatar
2002 C320- 2001 E430
bad cats
I really need an aftermarket replacement, if anyone cn suggest one.
Old Jun 26, 2007 | 02:58 PM
ohlord's Avatar
Smile cat/aftermarket option
racepages.com
50 bucks
call first to confirm part for right and left side.
eastern makes a lot of the oe replacements so quality is par.
anyone have a better supplier?It looks like they also have the whole system o2 sensors and all.
good luck
ohlord
Old Jun 26, 2007 | 07:24 PM
jlmills's Avatar
cat
Thanks, I will check them asap. That rattle sux!!!
