2002 e320 - Bad Seat Switch?
Old Jun 25, 2007 | 09:48 PM
cool_breeze's Avatar
2010 C300
Driver's Seat Switch: When trying to move the seat bottom back, sometimes it goes back and sometimes it goes forward! Does this sound like a bad switch?
If it is a bad switch, is it worth trying to clean, or just spring for a new one?
Thanks.
Old Jun 26, 2007 | 05:40 AM
MB>BMW's Avatar
G63 W463
mine does the same thing, weird...i know
i just let it go all the way forward, than keep pressing the button until it starts going back to where i want....and my headrest is completely out....
Old Jun 26, 2007 | 01:24 PM
4XFORE's Avatar
1998 E320 / 1992 LandCruiser / Project Car E30, 91, 318I
Do a search here. I thought I read it here before. By moving your seat all the way forward it resets something and the seat should work again.
Old Jun 26, 2007 | 07:50 PM
2010 C300
I did some searches and came across a post about a guy opening up and cleaning many little pieces in the switch. I'll look again to try to find the one about resetting the seat because that would be cool.
Thanks.
Old Jul 13, 2007 | 05:48 AM
edwingsiu's Avatar
have the same problem. i was told the module for the seats need to be replace and is very expensive. anyone knows how to fix it without replacing the module?
Old Jul 13, 2007 | 07:53 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Originally Posted by cool_breeze
Driver's Seat Switch: When trying to move the seat bottom back, sometimes it goes back and sometimes it goes forward! Does this sound like a bad switch? If it is a bad switch, is it worth trying to clean, or just spring for a new one? Thanks.
It sounds like the switch to me; first try the re-set method (either run it all the way forward, all the way back, or both). If that doesn't fix it then get a price for a new one, and if you think that it is too expensive, try to clean it.
Old Jul 13, 2007 | 07:56 PM
Musikmann's Avatar
Where is the seat module located on these cars? Maybe that can be cleaned too (?)
Old Jul 18, 2007 | 01:47 AM
Maddawg69's Avatar
1997 E320
Mine does the samething on the passenger side. I don't use the controls on the drivers side. I just use the seat memory. I just use the memory on the passenger side to get the seat to where I want it. I will try the all the forward reset tip next time. But does this fix it for a while or is it just a one time thing?
Old Aug 5, 2007 | 10:55 PM
silfad's Avatar
1996 E320, 1997 RL, 1992 735iL
I have been having the same issues with my driver's seat as well. The "moving forward trick" does fix sometimes. My main issue, though is that my back-rest and the up/down recliner won't adjust at all unless I use the memory buttons. I was thinking if it was the switch, then the memory buttons should not function at all!!!!!
Old Aug 6, 2007 | 04:29 AM
2010 C300
I tried another switch and the exact problem remains, so it's not the switch. Someone mentioned a seat control module (I think it's under the seat). This might be the source of the problem. Since I learned that the memory buttons still work, this problem has become easier to work around.
