Passenger Seat no workie
Any ideas out there?
It sounds like you probably found all of the fuse boxes and ruled those out. What about the switches on the door and/or the motor(s)? I think it unusual for all to fail at the same time, but maybe there is sone sort of junction that could be bad? There have been reports of front seats not moving forward and back; at least one was discovered to have had a coin lodged in the track. Good Luck.
I have to take it in this week to activate a warranty so I guess I'll get the ASE man to figure it out.
With use, the contact pins in the seat adjustment switch eventually break continuity with the circuit board. If the memory buttons work, you might be able to fix the problem by taking the switch out and putting a few dabs of solder around the contact pins.
As a reminder, all the functions were working when I bought it about 3 weeks ago. Now, passenger seat does nothing (but sit there annoying me!).
Does anybody know about the wiring between the door and the seat motors? Are there any more connectors/harness that could have come loose?
