Tire Pressure for 19" Rims?
Old Jul 8, 2007 | 01:02 AM
CLS550's Avatar
Subway
What is the recommended tire pressure for 19" rims no lowered? Its a 99 e320.
The tire size is 245-35-19 on front on rear and im keeping them at about 35 psi right now but i think thats too low. what do you guys keep them at?
Old Jul 8, 2007 | 01:29 AM
E43's Avatar
E43
2000 E430 Sport
I generally keep mine at about 35 psi also. What tires do you have, and what is the maximum pressure listed on the sidewalls?
Old Jul 8, 2007 | 01:46 AM
CLS550's Avatar
Subway
I have this tire on right now...
http://www.dunloptires.com/dunlop/di...00000&zipCode=
Old Jul 8, 2007 | 06:26 PM
CLS550's Avatar
Subway
bump.....
Old Jul 8, 2007 | 07:01 PM
ghaffar23's Avatar
'08 CL600 with 152k km; '01 E430 4Matic with 433k km; '17 Porsche Cayenne with 130k km
if it's consolation...
I have a set of 18's and I keep them around 40psi. Sure you will sacrifice a bit of comfort, but would you rather have a crack/bent rim, or less cushy ride?
Old Jul 8, 2007 | 07:05 PM
CLS550's Avatar
Subway
the thing is my front tires, the other side of each is wearing out a lot faster than the rest of the tire. The outer edges of both front tires are pretty much bald right now but the more inward the more tread there is. thats why im thinking my psi is too low.
Old Jul 11, 2007 | 06:20 PM
E43's Avatar
E43
2000 E430 Sport
Sounds like you might have an alignment problem. The recommended alignment settings for our cars suggest a little bit of negative camber in the front, which would cause inside tire wear, not outside tire wear.
Old Jul 11, 2007 | 07:00 PM
E420SportGT's Avatar
'97 MB E420 Sport/'88 MR2
huh? I've always thought that no matter what size tire/wheel combo you go with the tire pressure should always be the one stated in your glove box? Cause the pressure is what's supporting your car's weight?
Old Jul 11, 2007 | 08:07 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
If both outer edges of your front tires, or if it happens on the rears for that matter, I think that indicates that your pressure is too low.
