How do I reset the SRS light!!
Old Jul 12, 2007 | 06:40 PM
dpiechoczek's Avatar
How do I reset my SRS light after I took off my airbag and put it back on!!!!
Old Jul 12, 2007 | 07:47 PM
E420SportGT's Avatar
'97 MB E420 Sport/'88 MR2
any OBDII scanner should be able to. Try finding someone with one or else you might have to pay at the stealership.
Old Jul 12, 2007 | 08:28 PM
lol
lol, yea... thats true.
Can I just dissconect the battery?
Old Jul 13, 2007 | 07:21 AM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
You need a special scanner to reset it, not just the OBDII. Call around to some independent shops and find a sgood one who can do it. The dealers wanted $100 minimum for the 2-minute job - but my local shop did it for free (I gave him a $20 tip).
Old Jul 13, 2007 | 12:19 PM
Really? didn't know that. Last time my buddy he just used a regular scanner and reset the light :shrug: Maybe it was just a brake pad low warning...Good to know.
Old Jul 16, 2007 | 10:29 AM
Huachipato's Avatar
'04 Cobra & '04 S430
I'm pretty sure it is a self testing system. Correct the problem and the light will go off on it's own.
OBDII on my car does not pick up on the SRS errors - so I doubt that is the solution.
Old Jul 18, 2007 | 07:14 AM
Hirnbeiss's Avatar
Nope. It won't clear. I just had the same problem a few weeks back, setting the SRS light permanently when I turned the ignition on while the airbag was out. It doesn't clear itself - someone told me it's a law now.
The scanner used to clear it plugged into the connector under the hood, near the fuse box on the driver's side.
