Need Help Passenger Side Mirror Replacement
Old Jul 20, 2007 | 08:12 PM
handyman john's Avatar
E320 Wagon, '03 BMW 5 Wagon
Hello,
I need to change the passenger side mirror on my wife's 1998 E320 wagon. Autohausaz has aftermarket for the drivers side but not the passenger. So its off to the stealer I go !
Does anyone know what is involved (or have a DYI link) for removing and replacing the passenger side exterior mirror assembly ?
And does anyone have a used one they want to sell me ?
Thanks so much.
-John
Old Jul 20, 2007 | 09:07 PM
raymond g-'s Avatar
99 E320
you're talking about the whole package, right? (mirror, motor, bracket, cover)
should be quite easy (from memory)
1) fold mirror unit back to expose hinge innards
2) manipulate locking spring....slide plastic cover off
3) (3) phillips screws to remove. while continuing to fold mirror unit against
the door, remove top screw, then lower, inside screw.
4) then, allow mirror to return to normal position.
5) use long shaft phillips and remove lower outside screw
6) carefully unplug two weather proof electrical fittings
I was lucky enough to have picked up a immaculate pair on MBWorld for $85 shipped.
So scan the classifieds...as well as Ebay.
Old Jul 20, 2007 | 09:09 PM
ohlord's Avatar
Smile More
What color?give aurora auto wrecking in seattle a call they are on the web,Lots of E series parting out and plenty of mirrors.Raymond gave you the heads up on the replacement so you should be good to go.
www.youtube.com/watch?v=Qn0bgoME_mQ
might help a little
ohlord
Old Jul 21, 2007 | 03:51 PM
Raymond thanks for the directions and advice Ohlord.
Anyone ever tackle adding the late model W210 side mirrors with turn signal lamps to an older car ? (1998) that did not have them from the factory. Just curious.
Thanks gents.
Old Jul 21, 2007 | 04:26 PM
raymond g-'s Avatar
99 E320
pretty basic mod. i managed to do my 99 with help from jimmydagreek's notes
from years back....which you'll see mixed in with mine. it's much less daunting
than it appears, as the wiring from the LED light array is only twin lead: one
goes to hot lead (switched turn signal under door sill) and the other goes to
GROUND.
Old Jul 22, 2007 | 04:22 PM
devellin's Avatar
Smile Replace side mirror spring
I have a 1999 E430 and my side passenger mirror spring came off, can anyone tell me how to put the spring back? How do you remove the mirror cover? Raymond I like your PDF instructions, where can I view the MBUSA video to remove and replace this spring? Thank you very much!
Devellin
Old Aug 29, 2007 | 04:00 AM
rthiebaud's Avatar
1998 E320 W210
raymond g - Thank you for the information on replacing the passenger mirror on my E320. It was a piece of cake! It took a few minutes to get the "sleeve" off but after that it was easy except that the used one I bought had to have a few components from my old mirror. That was a pain... Thanks again!
Old Aug 31, 2007 | 01:35 AM
raymond g-'s Avatar
99 E320
r-
glad to hear of your success...and ease of R&R. it's one of those things on
the car ....if you've done it once, it's amazingly clear how easy it really is.
Old Feb 16, 2010 | 11:56 PM
dcollins90505's Avatar
E430 1999
Hi All,
Just wondering - I would like to do this mod but am looking for recommendations for the new blinking mirrors - I have a E430 1999. Any ideas?
