lamp malfunction warning
Old Aug 26, 2007 | 10:27 AM
hyacinth's Avatar
99 E320 4matic Wagon, 02 F250 Super Duty 7.3 4x4, 06 E55 AMG Estate
The other day I saw a the defective lamp warning and didn't really notice anything wrong as all the lights seemed to work fine. This morning, no warning message but I turned on lights but none of the exterior lamps work. This is on a 99 e320 4matic wagon. Any advice wd be greatly appreciated. Thanks!
Old Aug 26, 2007 | 01:35 PM
mbnj's Avatar
'06 E 350 4matic wagon; '05 E 500 4matic sedan; '09 S550 4matic
Obvously all lights out means not a bulb problem. Check fuses, if not you probably need to take it to someone who can check elctrical system for shorts.
Old Aug 26, 2007 | 02:45 PM
ohlord's Avatar
Headlight
Switch...........
ohlord
"GOT LIGHT?"
Old Aug 26, 2007 | 10:09 PM
GeorgeThompson's Avatar
Silver 2004 E500 4Matic
There are either 2 or 4 6watt bulbs in the tail lights. Barely noticeable. I had the "lamp malfunction" warming for about a month before i was annoyed enough to pull out the tail lights and check on it.
Old Aug 27, 2007 | 12:19 AM
mbnj's Avatar
The slightly trickier one is the brake lights, you don't get the malfunction when you start the car, just when you tap the brakes the first time and it stays on, then when you walk around your car with all the lights on they all seem fine because you don't have a foot on the brake to see the bad light.
