Car wont start- Electircal problems
Br
ak it down for us,did it turn over and fail to start?not turn over at all?or just the lights blinking and the clicking sound?Never disconnect the battery and try to jump start a computerized car,you can fry the electronics.Sounds like from the symptoms,that you have a bad ground,someplace.either on the battery cable to the neg post or cable to chassis.Check those first and the condition of the cable,corrision etc.,clean the posts and reinstall.Other then those few things,if on a 96 you have wire probs and the harness is fried,look up posts on that here and on benzworld.org.Not to hard of a job to diy if you need to.I still suspect it is a ground fault,so track it down.
BTW I didn't check where you live,but unless it is in timbuktu,you must have a good auto electric shop near by,No need for the dealer,they will just rip you a new one!Any good elec shop will be able to track a bad ground and fix it ,if you can't find it on your own.
Now as to the symptoms,confusing,you say it's like there is no fuel,no fuel and it would still turn over,so is it turning over or not?or just the clicking sound and the lights flickering?
ohlord
"GOT CODES?"
Also if you fill out the profile bar on the side,with year model and where abouts you are it helps cuz sometimes peeps live right in your area that can help.
Thanks for the help
ohlord
