Headlight Housing
Old Sep 14, 2007 | 10:06 AM
fluidmotion's Avatar
Headlight Housing
I have been looking into upgrading the halogen lights on my 97 E320. I noticed that some websites have two different headlight housings for sale, one for halogen and one for xenon. does anyone know if the housings themselves are the same? such as, did mercedes use the same glass/reflector for both xenon and halogen, only the bulbs are what would be different?
Old Sep 14, 2007 | 11:32 AM
amgqmp1's Avatar
'97 E320
Bump on this...I've got the same questions. I assume I need to stick to a halogen set unless I want to convert to HID ($$$). Basically, my headlights are kinda foggy...just want to get a new set of clear plastic on there.
Old Sep 14, 2007 | 11:59 PM
ZedStyle's Avatar
Youngtimer
usually you can't use the same housings with both xenon and halogen without getting a distorted beam pattern because of the different focal points of the bulbs, beam pattern, etc.
Old Sep 15, 2007 | 12:22 AM
raymond g-'s Avatar
99 E320
the exterior lens for reflector HID and reflector halogen have noticeable
differences. they are not swappable. is this what you're asking?
or, are you trying to ....
- convert reflector HID to projector HID?
- convert reflector halogen to projector halogen?
- convert halogen reflector into projector HID?
- or....?
Old Sep 17, 2007 | 10:01 AM
- or....?
After reading up on the subject, I would be looking at converting to new headlight housings that are projectors and getting projector HID's
Old Sep 17, 2007 | 10:42 AM
raymond g-'s Avatar
99 E320
cool, that's what i did. i purchased Depos...then extracted the Depo projector
inside and replaced with bixenon from E55. it is soooo, much better.
Old Sep 17, 2007 | 11:48 AM
ohlord's Avatar
Amg
you can polish the oem lens,search for the diy or ask how.Then if you want more light,go with the 65watt rally bulb from danielstern lighting.Longer life than oem h7 bulb and more light.
Just my preference,They throw more light then the depos and I cant stand the bluish look of those things.
"GOT LIGHT?"
