Wassup New to the forums need advice
what do you guy's think what should I look for/ask her
thanks guys
$8500 is not too bad but make sure the car is free of major problems. Likewise, check 1) CAT exhaust if they are loose 2) transmission module to see if it shifts smoothly from 1st to 2nd. I had that problem and replaced under warranty. 3) rear window regulator--I heard a lot of folks here experienced rear windows are not coming back up. 4) any ball bearings/joints that are loose or broken. Here are just a few.
I would take it to a reputable Benz shop to have a tech look over the car. Also, ask her for records of the maintenance the car had performed in the past.
hope this helps..
Jon
With the new benz out the 98 is now a ten year old car.
ohlord
have it inspected ,unless you are qualified to do it yourself.Time spent know making sure it is a good car is money saved later on..........
ohlord
