WTF? "SMOG" on AC display. Now gone.
Old Sep 24, 2007 | 11:11 PM
dan_cobb's Avatar
'84 911 Carrera & '01 E320
Question WTF? "SMOG" on AC display. Now gone.
The other day I noticed a 'new' word on the AC display panel. "SMOG" was under the left half of the fan spped graphics. I had never noticed this before so I took note. It disappeared by the time to looked a second time, which may have been several minutes.
I had not made any changes to the temp or fan settings. I had the AC on at a moderate setting for both sides of the car. Temp was probably set at about 70°.
I reviewed the owner's manual to see what it meant only to discover that it was not even mentioned.
What does it mean? is it possibly connected to the carbon filter; i.e. suggesting a replacement is due, etc?
Old Sep 24, 2007 | 11:23 PM
meooem1's Avatar
2004 e320 and 99 e320 wagon
i am pretty sure what happen was there is a sensor that monitors particulates in the air (smog or pollution). when the sensor detects a certain threshold, the charcoal filter kicks in automatically. hopefully u drove through a smoggy area or maybe you have a malfunctioning sensor..
Old Sep 25, 2007 | 12:48 AM
cscheat's Avatar
meooem1 is right, check your smog sensor !
Old Sep 25, 2007 | 10:18 AM
dan_cobb's Avatar
Living in Los Angeles I would be more shocked to find out that the sensor is malfunctioning than to believe the outside air was "smoggy".
Old Sep 25, 2007 | 12:47 PM
ohlord's Avatar
Good point Dan!!!
The smog portion of the climate control has no real value unless you are driving in a smoke stack...could you have been behind a bus?
For your own piece of mind,run the onboard climate control diagnostics to make sure all sensors are up to snuf and that there are no error codes.
http://www.eclassbenz.com/node/27
Have fun!
ohlord
"GOT CODES?"
Old Oct 8, 2007 | 11:49 PM
dan_cobb's Avatar
I finally returned to this post to find more information than I am able to digest at this time of day.
I'll bookmark the page and check it out the next time I have spare time.
Thanks for the absolutely more-than-complete answer to my question.
Once in awhile, my internal smog sensor goes haywire in SoCal, so it would be no shocker to find out the car simply had a 'cough'.
