how much oil does your w210 burn?
Old Sep 26, 2007 | 01:14 AM
daSong's Avatar
2001 W210 E320
I have the 3.2 liter and it burns about a quart approximately every 3-4 thousand miles. is that normal?
Old Sep 26, 2007 | 07:17 AM
uberwgn's Avatar
e300d
W210 cars:
we've got two diesels and one gasser in the family. None of them consume any measurable amount of oil during the oil change interval. All cars running a 229.xx oil.
Others have found that running crappy oil for years causes ring sticking problems and elevated oil consumption.
Old Sep 26, 2007 | 09:30 AM
43fatman's Avatar
2001 E430 Sport
In the past with my old 1986 124 and my fathers 126 did need 1-2 Quarts between Oil changes I recall. They were both high mileage motors with small leaks. I do not think it is that bad as long as it dose not increase much. Are there any leaks? a small drip over 5000-10,000 miles adds up.
Old Sep 26, 2007 | 09:35 AM
Quadcammer's Avatar
96 and 08 911 turbos
My 430 burns no noticeable amounts of oil. In 6k miles, I've added maybe an 1/8th of a quart, and thats because it was a little underfilled at its last oil change.
However, I would not be terribly concerned with 1quart in 4k miles.
Old Sep 26, 2007 | 03:13 PM
4ra4y's Avatar
E320
oil
what kind of oil are you guys using?
Old Sep 26, 2007 | 03:37 PM
E420SportGT's Avatar
'97 MB E420 Sport/'88 MR2
Mobil 1. No noticeable oil burnt. Change every 3k-5k miles.
Old Sep 26, 2007 | 03:48 PM
43fatman's Avatar
2001 E430 Sport
I am using Mobil1. 10W-40.
Old Sep 26, 2007 | 04:52 PM
chuck57's Avatar
2010 S550
Mobil1 - no measuable oil loss; follow FSS change recomennendations which so far seem to be about every 10-12Kmiles
Old Sep 26, 2007 | 08:31 PM
mike430sport's Avatar
2000 E430 Sport
oil
I drove from San Jose CA to San Diego and back to San Jose, on Labor day weekend. When I got back home I was down 3 quarts. I think it was beacuse I kept down shifting
Old Sep 26, 2007 | 08:38 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
no oil burnt here
Old Sep 26, 2007 | 09:06 PM
deloreandriven
Guest
Posts: n/a
For high oil cosumption these was a tsb to replace a rubber gasket in the area of the M.A.F . It's been a while since we have done any, but anybody that had concers with oil consumption have never come back.
Go see your local dealer, they should know.
Old Sep 26, 2007 | 10:13 PM
43fatman's Avatar
2001 E430 Sport
Strange
I got home and let my car sit for 15min and run the oil check and what do you know it says pit 1qt in I confirmed with stick. I have driven over 10,000 miles. I ran out just now and put a 3/4quart in. I do have a small leak around left Cylinder head cover nothing big. Oh well there you go!
Matthew
Old Sep 28, 2007 | 02:13 AM
patrick_y's Avatar
2006 E55 and 2002 E320
.... You need to give us more information here...
Do you drive short distances?
Do you drive a lot of stop and go?
Do you accelerate liberally?
If you answered yes to any of the questions above, then it shouldn't be a big deal that you're burning a bit of oil.
Old Sep 30, 2007 | 09:17 PM
citruspilot's Avatar
06 CLS500, 04 Tahoe, 04 Infiniti G35 Sedan, Boeing 737
My oil report. I had my oil changed with a synthetic blend back in May this year at 155,000 miles. I use Firestone for this procedure because they are good and the price is about $60.00. The sticker they put on said it was due again at 158,000 miles or in 3,000 miles. For whatever reason I didnt change it again until the other day at 161,000 miles because I had nothing better to do that afternoon. I added a whopping "zero" quarts to my car during that time. Now, I do check it often but found no need to add even a drop..................... Is that weird or what?? A 10 year old car with 161,000 miles not using even a 1/4 quart in 6,000 miles???
PS: My car does not drop one drop of any fluids of any kind EVER! I believe this car is possessed!
Jeff
Old Sep 30, 2007 | 10:37 PM
43fatman's Avatar
2001 E430 Sport
Jeff
Thats great! I have to agree with patrick on this one I checked yes to all three. Tho my old 4Runner could go 10,000 miles and not lose any oil and is still be a little translucent not dark black or brown.
Old Oct 1, 2007 | 12:46 AM
Eurosport's Avatar
monowiper
burning oil would be related to
valve seals
piston rings
first would be of course to check for all leaks, head gasket, valve cover gaskets, etc.
another thing with high mileage, could try a higher viscosity oil to see if it still burns oil, before tracking it down to valve seals, piston rings....
also a good Seafoam treatment might help
Old Dec 30, 2007 | 05:07 PM
MG's Avatar
MG
Veteran: Army
1998 E430; 2007 Porsche 911 C4S Cabriolet; 2011 Expedition EL Limited; 2014 E350 Estate
My 98 430 has been belching black smoke (not a lot, just enough to be seen) on startup for a while now, but my indy told me to ignore it. I get my oil changed every 4-5k miles and never had a problem with it.
I have 105k miles on it and am at about 4k miles on the last oil change. I do alot of highway cruising and very little around town driving in it.
I was up in Boston this weekend and the highways were clear, so figure 75-90 mph for 5.5 hours in each direction. about 30 minutes from home after driving 5 hours straight my car popped a "Oil at minimum level" messsage. Never seen it before. Stopped at a rest stop for 10 minutes and when I restarted the car the message was gone and did not reappear for the rest of the drive.
Thoughts? Recomendations?
Old Dec 30, 2007 | 05:15 PM
Peter Guenther's Avatar
92 500sel/01 320e wag
I have an 01 320 E with 60K, and change it by FSS and it is as full as when it was changed 10K ago and just about a year.
Old Dec 31, 2007 | 07:55 AM
Lancelot's Avatar
'01 W210 E320 CDI
W210 in sigpic. 231,000km no noticable drop in oil level between services (every 10,000km) running Shell Helix Diesel 10w40 oil...
Old Dec 31, 2007 | 02:14 PM
tirona's Avatar
1997 s320, 1997 e320
my e320 leaks oil from the timing cover, but i don't need to add any oil between oil changes (every 3k miles). i use mobil delvac 15w40.
Old Jan 1, 2008 | 04:56 PM
acarter53's Avatar
2018 C300 Cabriolet with AMG Line
About 1 qt every 12k miles
Old Jan 1, 2008 | 06:13 PM
tturner's Avatar
02 E320 Sport
I am burning about 1.5q or so every oil change (10,000 miles or what the FSS says). I am approaching the 100,000 mile mark. Dealership looked at it multiple times and indicating it is "normal". They did replace some seals, including the pan seal twice.
