Missing Pixels
Old Oct 2, 2007 | 09:15 AM
Britrover's Avatar
01 W210 E Klasse | 02 W 463 G-Wagen | 06 Land Rover LR3 HSE
Missing Pixels
Having a new issue on my 99 E320. The climate control unit is missing part of pixels on the passenger side display , strangely enough this problem was right after we have the interior carpet shampooed and the engine steam cleaned.
Is it a possibility that some water splashes got in the climate control unit causing this issue or is this is a common issue as the car ages. Also any input on potential fixes …..if this isn't a DIY exercise I will take it to my mechanic.
Old Oct 2, 2007 | 09:47 AM
timatherton's Avatar
Missing pixels
I had a similar problem on an Audi 100 quattro on the dashboard info panel I used to have. It's just a tiny bit of dirt and/or corrosion interfering with the connections.
I disassembled the whole panel and cleaned all the contacts with metholated spirits and an old toothbrush and sometimes a suade brush (if the contacts were particularly corroded) prior to re-assembly. The question is . . . do you feel brave enough?
Old Oct 2, 2007 | 12:37 PM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
This is a common problem and they're missing on mine too. It hasn't bothered me enough to spend the $250+ bucks to have it repaired but it's up to you. You need to find someone outside of the dealer to repair them. There's someone on ebay fixing them but you have to remove and send your cluster for the repair, which will leave you without a car for a couple days.
Old Oct 2, 2007 | 12:47 PM
Quadcammer's Avatar
96 and 08 911 turbos
he is referring to the climate control unit, not the dash clusters.
Mine is missing the "auto" label.
Doesn't really bother me.
Old Oct 2, 2007 | 01:20 PM
Oops! Thanks for the correction I was reading too fast, lol...
Old Oct 27, 2007 | 07:46 AM
lciambotti's Avatar
2000 E320 Mercedes
Same problem
I have the same problem, but my temp. indicator works when it feels like it. I can look down and see 1/2 a 6 and a 9. The next minute I'll look down and see the whole 69. Then next time its blank. Where is the temp. sensor? I also have issues with the clock. Most pixels are out. Has anyone taken a shot at fixing these problems?
Old Oct 30, 2007 | 09:42 AM
mdsjsb's Avatar
07 e350 127k 02 320e 124k miles 93 300e 3.2 liter 221,000 previous 89 300e 200,000
clock pixel problem too
Just got a 2002 320 e series. Clock has pixel problem, appears to tell time properly but display is missing some pixels, example - an eight looks like a 3, 10 11 12 are real problems - its mainly the hour thats messed up.
Old Nov 1, 2007 | 10:14 PM
FlaBoy239's Avatar
I have the same problem. My clock and gear display in the gauge cluster is almost completely gone on my 2000 E320. Is there any way to fix this without sending to a shop? I kinda miss the clock. My Alpine has one but it's kinda small.
Old Nov 2, 2007 | 12:07 AM
ohlord's Avatar
Search
the posts for display repair,maybe raymond,send it out they send it back fixed.You could pick up a salvage yard one if you don't want the down time,easy r/r.
ohlord
Did the display just die,or did all you guys buy used mb's with already dead pixels?just wondering........
Old Nov 7, 2007 | 09:04 PM
lciambotti's Avatar
2000 E320 Mercedes
Missing pixels
I just purchased my 2000 E320 with 44K miles on it. The pixels were already gone or displaying when they feel like it.
Old Nov 7, 2007 | 09:08 PM
ohlord's Avatar
Did
you inspect the car?why did you buy a car with a faulty display?did you get it from a dealer?Did they knock off a ton of money to sell you a car with a failed display?How much did to pay for the recently purchased car with the bad display?
ohlord
"GOT CODES?"
Old Nov 8, 2007 | 02:07 PM
mdsjsb's Avatar
Missing codes??
ohlord
"GOT CODES?"
I did inspect the car ans I believe I got a good deal on the car , under 18K with only 39k miles. They are going to fix it, just was adding to someones lament. You certainly offered up a lot of help.
Old Nov 9, 2007 | 07:46 PM
lciambotti's Avatar
2000 E320 Mercedes
Missing Pixels
I knew they were out, but I got a good deal, 17K with 44K miles. I'm a fix it kind of guy. I figured I could fix it myself. I am surprised no one has posted a thread on how they fixed it themselves. I recently sold a BMW 740I. Their was a BIMMER website that dudes fixed everythng. I only had to have a mechanic look at it once. Every other time, I got a "how to" from that website.
Old Nov 9, 2007 | 08:57 PM
ohlord's Avatar
A
good deal on a 2000 is 10-11 grand so if you paid $17,000,the least you should have expected was that the display worked properly.
Those are tiny little pixels and the place that repairs them for about $250 has all the supplies and special testers to do the repair.If it were a Connection or harness issue,someone here or on benzworld.org has a fix,you just need to search it out.
Interested in more DIY related issues bounce between her and the diy section at benzworld.org w210 section.Between the two sites and the knowledge base of the forum members you could build a w210 from the ground up.
