E280 1998, engine trouble after driving manual mode
Old Oct 13, 2007 | 06:56 PM
youseffex's Avatar
E280 1998
I've had a white E280 1998, auto-matic transmission for less than one month and i got the silly idea to drive while in manual mode, i switched from gear one to 2 to 3 appropriately while slightly over revving the engine when all of a sudden the car seem to jolt then i slowed down and the engine turned off by itself.
I put the gear on P mode and turned the car engine on but it ran for a very short period then the engine died off again, the same while on N mode.
While the engine is briefly on it would respond very erratically when i press on the gas peddle and sometimes doesn't respond and just dies off again, there is no funny smell and all electrical systems seem to work fine, no over heating problem and weather temp. is 28 C.
in brief the engine starts fine but instead of keeping steady rpm it would slowly decrease until it shuts completely down, i want to fix it but i need the background before i get tossed around by greedy car mechanics.. am i in for a big pocket drain? tell me please what you think the problem is and how to fix it.
Old Oct 13, 2007 | 07:22 PM
ohlord's Avatar
Where are you located?
First get your system scanned to see if any codes are present.
then you need to go to a good muffler shop and have them check the cat converters,could be one of them is partially blocked and that was the jolt and now the reason for your strangled engine.
I would start there and then proceed further if not solved.
Any good indie shop can scan the codes or put it on a scope.The scope will also show o2 sensor function and show cat converter failure.
Old Oct 18, 2007 | 04:16 PM
youseffex's Avatar
E280 1998
Thank you ohlord for your helpful post,,
I have just retrieved my car from the garage in a very good condition, the mechanic had to change or fix the following:
-changed what he called "air watch"
-changed one ignition coil
-changed crank sensor
-general electrical wiring maintenance
-cleaned the injectors
-changed engine seats. -previous vibration problem while car is idle-
I'm now 800 bucks poorer but problem solved.
Old Oct 18, 2007 | 04:52 PM
ohlord's Avatar
If you
had all that done by a shop,you got a fair deal,most shops would charge way more for doing less.Diy would be less,but seeing as you are new to the make,you found a good shop.
