Need Help!!!
Old Oct 15, 2007 | 02:43 PM
BOMBER's Avatar
1998 E320
Need Help!!!
Hello everyone,
I am having a problem with my vehicle stalling.
Before I take it to Autozone to see if they can give me the code or take it to the dealership.
I was wondering if anyone has gone through this issue.
This just started and has only done it a few times this weekend. I was driving and all of a sudden the car dies and there was no warning of any sort. No noise or any type of hesitation from my car. The car tries to turn over. Not sure if its fuel or ignition. What I thought was strange is that if I let it sit for a bit it will start again other then that it wont.
Thanks,
Old Oct 15, 2007 | 03:10 PM
ohlord's Avatar
Classic
crankshaft position sensor,symptoms.When they start to go south heat makes the symptoms worse.Cools down after 20-30 minutes starts again,repeat.Correct?Easy diy,pics and all over on benzworld.org w210 forum diy section.Part online at autohausaz.com called for short CPS.
If you get the codes read they may say multi cyl misfires or a clear cps code.Most times it won't show the code except for the misfires.
Old Oct 15, 2007 | 04:44 PM
BOMBER's Avatar
1998 E320
Thumbs up
Yes, you are dead on... I went earlier to see what type of codes I had. Which is CPS. I went and already picked up the part for $80.00 and I will replace it... Thanks again.
