SOS W210 in trouble!!
First time poster...big time noob btw , just a heads up
SO I am the proud papa of a w210 but it needs some interior help
-Door handle (stock) upholstery is coming off, is there a way to fix that?
-My switch to control the passenger windows is broken, need a brand new module... where can i get one?
-My storage compartment right under the radio has a broken cover so its jammed and it wont go anywere, does anyone have a quick fix or does this require a whole new replacement?
as a side note how tough is it to change out the pedals for an amg pedal set?
1 Post
'04 Silverado Z71 - sold all my Benzes and need another!
You should enter where you're located in your profile so we can better help you. If you are in the So. Cal. area I have a couple of junkyards you could call...
Where
are you located?
3m makes upholstery spray for the peeling problem.
follow this video to remove the cubby storage as they call it
http://w210.pietrzyk.net/disassembly_interior.htm
just proceed to the point of the ash tray removal,no need to remove the whole console to get the cubby out proceed to this video
http://w210.pietrzyk.net/disassembly_68inter_step2.htm
the springs and cams on the side of the cubby probably got sprung so unless you can figure out how to fix them,or reassemble them you need to replace the unit.I have one for 120 shipped if you can't find any cheaper.May have a working module also,although I would check the window motor first to make it is the switch.
hope this helps.
hope this helps.
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
