2000 MB E 430 No CD Changer
Old Oct 15, 2007 | 04:59 PM
Theonkangnia's Avatar
E4 430
Does any one experienced " No CD Changer" and how did you correct the problem. Audios was working fine i got the message after changing CDs. Radio is OK. Car has 58K Miles
Any suggestion will be appreciated.
Regards
Old Oct 15, 2007 | 05:52 PM
ohlord's Avatar
Open the cd
bin and pull out the holder,insert it back in the holder and slide the door closed.Then with the key on to start, turn the radio on and off several times.Now see if the changer is in comm with the head unit.Sometimes they fail to sync with each other.
if not ,have your radio code handy and disc the neg cable and step on the brakes a few times to reset the system and re hook up the neg cable,sync your windows,enter the radio code and you should be good to go.
Old Oct 15, 2007 | 11:14 PM
Air Marshall Eldritch's Avatar
John Deere
What he said. But I get it from time to time, and I just turn the car off, pop the trunk, pull out the holder and snap it back in, then start the car. Problem always solved.
Old Oct 22, 2007 | 08:19 AM
dotsmercedes's Avatar
Mercedes E430 2001
Thumbs up Hey, it worked (1st procedure). Thanks much!
Dealer insisted we needed a new CD changer ($400). I'm not sure what they would have wanted for the install. This seemed like B.S., as I was pretty sure it was mearly a communication issue. Thanks to you & your expertise, we now have a working CD changer again. You deserve that BOW...
Old Oct 22, 2007 | 08:55 AM
vinceC's Avatar
2014 ML350 4Matic
I had the same problem and was able to fix it the same way - for a while. Finally it just wouldn't work anymore and I had to replace it.
Old Nov 1, 2007 | 01:40 AM
JDB's Avatar
JDB
CLK63 Black Series
I also have the "No CD Changer" problem, and was able to correct it, temporarily by removing the CD Cassette and the re-inserting it. But, now a new problem has occurred. The CD Cassette will not eject from the unit when I press the eject button. Any suggestions before I head off to the friendly dealer?
JDB
Old Dec 3, 2007 | 03:26 PM
EdzBenz's Avatar
W210 W140
JDB
I have the same exact problem. Anyone fix this?
Old Dec 3, 2007 | 04:25 PM
ghaffar23's Avatar
'08 CL600 with 152k km; '01 E430 4Matic with 433k km; '17 Porsche Cayenne with 130k km
La Jolla Audio out of Cali. Google it. They will take care of you just fine. I fixed mine there for like $275 or so last year.
Old Dec 3, 2007 | 04:46 PM
EdzBenz's Avatar
W210 W140
I appreciate the information. Did you have this exact problem with your CD changer before you had fixed it? If not, what was wrong with yours?
I'm not sure I want to spend that kind of money just to fix the CD player.
Old Dec 3, 2007 | 04:48 PM
Britrover's Avatar
01 W210 E Klasse | 02 W 463 G-Wagen | 06 Land Rover LR3 HSE
There is a DIY thread under W210 E Class with pictures that should fix the issue you all are encountering. I will search from home and post the url……………….else do a search
on benzworld.org and you will find the post.
Good Luck
Old Dec 3, 2007 | 06:19 PM
ghaffar23's Avatar
I had the exact same message on my radio, and the CDs would not play or recognize that I put the magazine in. I talked with the guy that fixes them and it is actually a defect with these Benz CD changers. It occurs pretty often, and the life of the changers are anywhere between 3 and 5 years. After that they quit. My mom's changer in her W215 just quit, and I have to fix hers as well. Poor Benz quality prior to 2007 sucks. Gotta fix it or get a new one.
Old Dec 3, 2007 | 07:49 PM
Franasia's Avatar
2000 E 320S4 210.282 4Matic Estate
I recently fixed the "no magazine" problem that had for over a year by means of making it run with the cover removed and wiggling with some of the exposed levers and gears - just a little bit. It run like a charm for over two weeks and now have this other issue of not being able to eject magazine.
I'll find some time this week to open it up again and will post back.
Cheers
ohlord's Avatar
check
the fuse for the player.no power no eject.
Old Dec 3, 2007 | 07:54 PM
Franasia's Avatar
There is power. The green eject light on button does light up but it will not eject.
Old Dec 3, 2007 | 08:39 PM
Britrover's Avatar
All W210 Mates who have issues with their cd changer........kindly go through this thread with pics. I am sure this will help
http://www.benzworld.org/forums/w210...air-guide.html
Old Dec 3, 2007 | 08:55 PM
Franasia's Avatar
Thanks Britrover, I had already seen it but mine does not have that angled optical plug but a straight one that fits OK. I guess this is a revised plug, so the problem must reside elsewhere.
Cheers.
Old Dec 3, 2007 | 09:04 PM
ghaffar23's Avatar
Here's the La Jolla Audio link. This will fix the CD changer properly because the problem lies in some internal components no longer working. There are temporary solutions out there, but this will work.
http://lajollaaudio.liveonatt.com/information.nxg
