fog light wiring harness
Old Nov 21, 2007 | 12:54 PM
fju2112's Avatar
2002 E320 4matic 92K (bought 12/20/06). 2000 E430 4matic (RIP 12/9/06) :(
thanks to ohlord, I was able to get at the fog light flap that covers the housing under the car. once i can jack it up this weekend i'll try to get the wiring harness & bulbs replaced.
before i do that, i ordered updated wiring harnesses from the dealer and have them. It's not just the wiring harness in the plastic but two metal pegs with a couple of additional parts. in case i jack it up and don't see where these pieces all fit, is there a DIY on here for fog lamp wiring harness? I don't see it on here or benzworld.org.
thanks!
Old Nov 21, 2007 | 06:07 PM
zx11blade's Avatar
2001 E320, 2008 E63 AMG
When I did mine it was plug and play.
Old Nov 21, 2007 | 09:49 PM
fju2112's Avatar
I guess I"ll try it out and see if I have a need for that additional set of parts they provide...
Old Nov 21, 2007 | 10:14 PM
zx11blade's Avatar
What part of Boston are you from? If you need help you can check me out.
Old Nov 21, 2007 | 10:16 PM
fju2112's Avatar
I think I should be okay once I get it on a lift...I live off 128, just a bit north of waltham, and would be going kind of north shore to get to my parent's house to try this out. if I get it on the lift and still have troubles I'll take you up on the offer! where are you at?
Old Nov 22, 2007 | 04:11 AM
MB>BMW's Avatar
G63 W463
could you please post a pic of what the updated part was that you bought from the dealer?
Old Nov 24, 2007 | 08:41 PM
zx11blade's Avatar
I am in swampscott. Let me know if you need help.
Old Nov 25, 2007 | 03:21 PM
fju2112's Avatar
tried getting at the wiring harness today - the end that plugs into the fog lamp is, of course, easy to locate. the other end is hidden up and inside the bumper in a place where one can't see after lifting up the hood. my fingers could feel up and inside the space where the fog lamp wire presumaly plugs into something else, but when going in from the hood, you're pretty much flying blind there too.
couple of questions:
- what is that sensor that is by the fog lamp (driver's side, maybe on passenger side as well, didn't look)? both sets of wires go up and onto a platform and seem to be held together by some sort of plastic tie. not sure where the wiring harness plugs into after that as I couldn't get a good view? I was toying with the idea of trying to cut the plastic tie, but i'd be doing it blind and would probably have cut a wire.
- does the sensor wiring harness and the fog lamp wiring harness come together, then back down into the same compartment, with both wires eventually plugging into the same metal box above the fog lamp...? just wondering if this is where both lead?
well, at least i know how to change the bulbs if i need to...
Old Nov 25, 2007 | 04:52 PM
ohlord's Avatar
That little nib sensor
in the slot near the fog drivers side is the outside temp sensor that shows on your inst. cluster.
Old Nov 25, 2007 | 04:59 PM
fju2112's Avatar
awesome..that's what i figured! as for actually getting at the other end of the fog lamp wiring harness, anyone done this before?
Old Nov 25, 2007 | 10:00 PM
fju2112's Avatar
mb>bmw - here's the picture of the part number, etc. of the part i bought (x2):
here's a picture of the whole part:
here's a picture of the label w/ part number:
extra parts i'm not quite sure what to do with:
Old Nov 26, 2007 | 06:50 AM
Franasia's Avatar
2000 E 320S4 210.282 4Matic Estate
fju2112:
I think you you would have to remove the front bumper cover to replace these harnesses. It's not difficult at all. Hopefully everything should be clearly exposed.
Cheers
Old Nov 26, 2007 | 07:40 AM
fju2112's Avatar
Originally Posted by Franasia
fju2112:
Cheers
Hey Fran - thanks!
I should have taken pictures while I was in there. There appeared to be a thin metal platform onto which the temp sensor wires and fog lamp wiring harness rested, tied together. I'm not 100% sure of what happens to them from there but it APPEARS all of the wires are tied together then brought back down into that same compartment and plugged into a metal box. that's above my level of expertise even if I could figure out which wires went where and was willing to tear off the electrical tape that kept the wires together, i still wasn't 100% sure of what the wiring harness plugs into.
Definitely need to invest in a bentley manual or WIS DVD
Old Nov 26, 2007 | 08:20 AM
zx11blade's Avatar
Let me know if you need some help
Old Nov 26, 2007 | 08:30 AM
fju2112's Avatar
zx - you can share your input on the wiring harness if you'd like...since I can't get a good look at it, you can tell me if that and the temp sensor wires are tied together and where they go exactly? will make my job easier if i go back in there soon.
Old Nov 26, 2007 | 07:25 PM
Franasia's Avatar
fju2112,
This is what it looks like with the bumper cover removed. The fog lamp on the LH on picture is held by a piece of wire so it won't hang from the harness. I figure by the length of your new harness you might be able to determine its location on the photo or where approximately it hooks up to.
Hope it helps.
Cheers
Old Nov 26, 2007 | 08:12 PM
fju2112's Avatar
hey franasia - thanks for the pic! the bumper, in this picture, is hiding the end of the wire that plugs into...whatever it plugs into. if you have a shot of that same thing but from a birds-eye view, i bet we'd find that the wiring harness is tied down to the bumper and then re-routed back down to plug into a metal electrical box. i know that on the dirver's side it appeared to be the case with the temp sensor wires being taped together w/ the fog lamp wires. since i couldn't see where this join occurred, though, i can't say for sure.
anyone with a WIS dvd?
Old Nov 26, 2007 | 08:37 PM
Franasia's Avatar
I took a series of pictures of the front end when working on the horns last year. Sorry I do not have the view you want.
Cheers
Old Nov 29, 2007 | 04:10 AM
MB>BMW's Avatar
G63 W463
thank you for the pics
Old Jan 4, 2008 | 04:41 PM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
What did you finally do? I've got this job on my own honeydew list.
Old Jan 5, 2008 | 12:41 AM
fju2112's Avatar
hirn - took it to my mechanic for 100K service after buying the new "heavy duty fog light wiring harness" and had them deal w/ it :-) didn't want to mess around w/ the wiring myself, i'm a novice.
