Xenon headlamp internals x-fer to non-Xenon lamps?
polish the lenses and install the 65watt rally bulbs from
www.danielsternlighting.com
and save yourself the money
use it to get your transmission fluid changed
Use a heat gun to heat up the seal around the lens to access the Headlight internals ..and RESEAL the lens when installing
Any suggestions for repairs. Plan of attack was to carefully remove from housing, place on towel with a piece of wax paper between the towel and reflector and using an adhesive, i.e. JB Weld....
Suggestions?
I know that the shape of the housing is slightly different and that the lenses are different also.
After holding it in place for about 1 min and letting sit for approx. 3 hours, it feels solid, although I didn't try to forcefully rip it apart but I gave it a light twist and nothing was moving....
I chose this super glue as it is in gel form. I didn't want the item to set on initial contact in case you didn't bring the parts together 100% on the first attempt.
Downside. It takes some time to cure, depending on the repair. Enjoy!
