Service a-b
Old Feb 14, 2008 | 11:04 AM
Hi Fi's Avatar
2001 Black E320 4Matic -2002 Silver E 320 4Matic Wagon
Service a-b
I am wondering where could I get the info on what is done for service A and Service B and how to reset after the service.
Thank-You.
Old Feb 14, 2008 | 11:34 AM
raymond g-'s Avatar
99 E320
https://mbworld.org/forums/showpost....94&postcount=1
Old Feb 14, 2008 | 11:39 AM
ohlord's Avatar
Generally
http://www.geocities.com/mymercedesb...e_a_and_b.html
diy'son benzworld.org w210 diy section.
simple checks that you should be doing whenever you check over the car.Look at belts,hoses etc. Anything out of place,loose wires,blown bulbs.Proper oil specs and fleece filter.
Parts at autohausaz.com
germanstar.net
fss reset in your manual,you don't state what year model so we can't tell you the procedure.It changes depending on year.
ohlord
get out the tools
Old Feb 14, 2008 | 12:34 PM
Hi Fi's Avatar
2001 E 320 4Matic
Old Feb 14, 2008 | 12:53 PM
ohlord's Avatar
FSS reset
http://www.analogstereo.com/pdf/om/m...anual_2001.pdf
how many miles on it?
Over 60k miles get the transmission fluid changed and the filter,mb spec fluid only.Diy on benzworld.org and mercedesshop.com
have the transfer case serviced on the 4matic.
ohlord
Old Feb 14, 2008 | 02:58 PM
Hi Fi's Avatar
What is the transfer case,and the fleece filter.
Thanks for the recommendations.
Old Feb 14, 2008 | 03:06 PM
ohlord's Avatar
transfer case
for the 4 matic needs to be serviced and the transmission needs it.The fleece filter is for the oil change it goes hand in hand with the 0w40 synthetic engine oil so the filter lasts as long as the 10-12k mile oil change intervals.
you will see it under oil filter kit in the autohausaz.com section for your model and year.
