will these tires fit?
Section Width: 9.64 in 245 mm
Rim Diameter: 16 in 406.4 mm
Rim Diameter: 17 in 431.8 mm
Overall Diameter: 25.31 in 642.87 mm
Overall Diameter: 25.68 in 652.27 mm
Sidewall Height: 4.65 in 118.11 mm
Sidewall Height: 4.34 in 110.23 mm
Radius: 12.65 in 321.31 mm
Radius: 12.84 in 326.13 mm
Circumference: 79.51 in 2019.5 mm
Circumference: 80.67 in 2049.0 mm
Revs per Mile: 821.8
Revs per Mile: 809.9
oe v.s. proposed 245/45/17
11 revs per mile is not 8% TC will be fine
****the biggest issue is what offset on your current rims?
are you lowering the car?are you willing to roll the fenders?
Slap them on and drive it,lock to lock over a few tracks
you'll find out soon enough
ohlord
31-35 et front would be no problem.How close were your 235's?
If to close at least you have some staggered tires for the rear
and you sell the other two for 2bills
