2000 E430 MAF question.
I pulled some codes from the vehilce and they indicated changing the front o2sensors. Done, runs better but still rough idle and can't hammer it without sputtering but can slowly accelerate to high speeds with ease.
I believe it is the MAF, so I run car until CEL comes on again. Pull codes and they are P0170 and P0173 which is either vaccuum leak or MAF, but most likely MAF.
Now, I look at my MAF for some information and all it has on it is PBT-GF30, which after research I come to find out on eBay that this is a "high quality after market part", sold for half the price. Hmmmm???
So it appears the sensor went bad on the vehilce at some point and was replaced with a cheapy that worked for awhile and is now dead.
My question is, can I just buy the Bosch MAF sensor insert for $140 from Germanstar.net or should I just replace the whole cheap piece of crap with a new BOSCH complete MAF sensor and housing for $179.95 from Importecparts.com.
Has anyone purchased from these vendors before?
Thanks!!
. For the price difference, be safe and do it once. German-star is very good to work with. I don't know about the other vendor.
http://www.autohausaz.com/search/pro...0Mass%20Sensor
unplug it while running if no difference it is dead replace it if a noted difference clean it with crc brand maf cleaner per the diy on benzworld.org w210 section diy.The whole section is a must read anyway
ohlord
The germanstar insert is an exact match and on the 3.2 engine saves about 40 bucks,on your 430 for the price get the new unit.
BTW the insert is not calibrated to the maf.So if you ever go the insert route they work
and always check before you buy anything autohausaz.com prices are far better than the place you were looking at and they have greater access to more parts and free shipping over 50 bucks.
Another tip always throw a code up on a post sometimes it is best to let the experience of the masses suggest a solution.
ordered the new part from ohlord's link on autohausz.... 141.83 no tax free shiping.
Thanks to everyone for the help with htis fix.
Now if I could only figure out how to get new steering control button since mine are melting!!!
Thanks again!!
mf.
any ideas??
Thanks.
