Car died out while driving!!!
Old Mar 16, 2008 | 04:27 PM
pimppoet's Avatar
2006 CLK350
I was on my way to walmart when my car just started to slow down. The brakes tightened up & I had to pull over on the side of the road. I tried to restart but it was a no go. After while 30-60min I tired it again & it started up after afew tries. Only recent problems I had was with my brakes which need to be bleed. The mechanic refered me to the benz dealership in regards to the abs system because it was the 2nd time bleeding them.
Edit: I peeped afew other related noting it maybe the cps senor. If its a senor issue how much should I expect to pay?
Old Mar 16, 2008 | 05:21 PM
ohlord's Avatar
What
year and model w210?
Brakes were hard because you lost power so no power brakes at that point.
Does it start now?Have you checked the charging and battery system?
CPS is only about 70 bucks at autohausaz.com and easy diy on benzworld.org w210 diy section,you can do it.Check all the other things first.
ohlord
Old Mar 16, 2008 | 05:38 PM
pimppoet's Avatar
2006 CLK350
ohlord
99 e320. After I got home I parked it for the night. It started up this morning so I drive around the block & the same thing happened. I had to wait again to start it up. Far as the electrical system the lights,radio etc all work. The only error message prior to that was in regards to the brake sensor. I was thinkign about the diy option but from what I seen my hand maybe to big to get it done right.
Old Mar 16, 2008 | 10:25 PM
mbnj's Avatar
'06 E 350 4matic wagon; '05 E 500 4matic sedan; '09 S550 4matic
I went blank on its proper name but my guess is its a certain sensor that went bad. It keeps telling the system incorrectly that something is wrong and the system shuts itself down. It should also hold a code which you can check. I wish I could recall the proper name but its not the brake sensor, that's just a function of power loss. If its what I'm guessing you should get the stall out most often when braked or idling in park and in an emergency you can work both feet to keep the engine slightly revved when forced to stop at a light, traffic, etc., until you reach home.
Old Mar 17, 2008 | 12:01 AM
ohlord's Avatar
Cps
it really is not that tight a space if you remove the engine cover and be wary of the sharp heat shielding.A flash light and the diy is all get er done.The brake warning came on because of the power loss and the cps usually does not throw a code unless failed kaput
ohlord
Old Mar 17, 2008 | 02:11 PM
pimppoet's Avatar
2006 CLK350
Im having trouble locating it. I checked the threads below but im unsure exactly were to look for my car. Also while checking on the cps issue ive seen it called both cam & crank position sensor & with differnt parts. Whats really what?
http://www.benzworld.org/forums/w210...ghlight=sensor http://www.mercedesshop.com/Wikka/M112M113CPS
Is this the cable being referenced to in the diy guide above?
Old Mar 17, 2008 | 05:14 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
The problem might have been caused by your destination, Walmart is not a nice place to go.
